rear disc brake kit - Ford Powerstroke Diesel Forum
Old 09-07-2010, 03:01 PM
rear disc brake kit
who makes em, whos the best and can i just swap the stuff from a newer 10.25 over to mine
Old 09-08-2010, 09:46 AM
TSM mfg
no you cant just swap the newer stuff over,
'85-'98 Ford Sterling
Old 09-08-2010, 09:51 AM
drives a ranger
Send a message via AIM to kanuck15
you can piece together your own kit for much cheaper than that
http://cgi.ebay.com/ebaymotors/Ford-...item3cae955190
http://www.napaonline.com/Search/Det...+50028+2028058
http://www.napaonline.com/Search/Det...+50030+2030028
then add front brake pads for an 1985 chevy K1500 and the banjo bolt brake lines for an 1985 chevy (one per side) and you are good to go
i have a couple thousand miles on my set up using those exact parts and it was cheaper that way
Old 09-11-2010, 11:17 AM
X2 for TSM - can't beat them. Mine work great and TSM's kit comes with all hardware, brackets, pads, ect.... and their customer service is top notch. The owner drives an OBS and is really helpful.
Old 09-15-2010, 10:36 PM
as far as i know you can get the the rear disc brakes from a 99ish super duty at least the f250 and its almost a bolt on if a can remember right ford used the same rear axel so if you can find a sd around that yr at the junk yard measure the bolt pattern in you rear axel for the drum breaks then measure the bolt pattern on the sd cause thats what im planning on doin on mine
Old 09-16-2010, 01:19 AM
drives a ranger
wont work sadly. As soon as the Super Duty platform hit the ground it had 8x170mm bolt patterns on it
Old 09-16-2010, 06:02 AM
Bingo. E-series vans I hear have rear discs though.
Old 09-16-2010, 08:33 AM
I will sell you my complete TSM brake kit for $250 + shipping since I can't use it after switching to a dually rear axle.
Old 09-16-2010, 09:12 AM
drives a ranger
^^ thats a deal right there
Old 09-16-2010, 08:48 PM
Electrical Ogre
Unfortunately the e-series and super duty use a different flange on the axle to mount the disc bracket compared to the OBS drum. The econoline van uses a Dana 60 rear instead of a sterling, so that's not easy either. You'd have to cut the old brackets off, and weld on a carefully removed set from a donor axle. The econoline rotor would have the correct bolt pattern.
http://www.fordmann.com/F350.rear_disc_brakes.htm
