fpr shim?? - Ford Powerstroke Diesel Forum
Old 08-25-2010, 06:27 PM
fpr shim??
Ok first off what is a fpr shim and does any one have a write up/pictures on how to do it and what are its benefits? Any info would be great thanks.
Old 08-25-2010, 07:04 PM
drives a ranger
Send a message via AIM to kanuck15
It bumps up the fuel pressure on higher mileage trucks. Just stand directly infront of your truck and find the fuel filter. Look to the right slightly. A small grey boxish piece on the filter housing. Take the brass plug out its a 17mm. Be careful not to lose the spring or the shuttle in there. Put a 3/16ths bb in the shuttle and reinstal the spring. Then check your fuel pressure. Don't go above 70psi
