Upgrade - Ford Powerstroke Diesel Forum
Old 08-20-2010, 01:37 PM
Thumbs up Upgrade
I would like to upgrade for a new turbo, right now i have a 1995 f-350 with a stock turbo and i would like some advice for some good turbos and prices. Please help, thanks
Old 08-20-2010, 11:53 PM
how much power do you want and how much do u have to spend??
Old 08-21-2010, 12:39 AM
Have you checked out the OBS specific threads? Lots of really knowledgeable guys to bounce questions off of.
Old 08-21-2010, 02:14 AM
Get with some of obs guys, but it is my understanding that a modded H2E is the way to go for the obs trucks since a GT38R won't just bolt on. Of course depends on power levels you are looking for though too.
-Aaron
Old 08-21-2010, 02:33 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
put a stock SD turbo on it is a good upgrade and you can run the 38r too
Old 08-21-2010, 02:36 AM
I thought the obs trucks needed some extra parts to make them work, in which case the h2e should be cheaper and similar, maybe better performance.
Old 08-21-2010, 04:11 AM
Real Men Love Jesus! <><
if you upgrade to a SD turbo style, you will need up pipes, mounting flange from a 99.5 and up truck. You dont NEED a intercooler, but it would greatly help. a stock 99 and up one works fine. you will need a set of boots, pipes and the Y pipe of the turbo and the bigger 3" intakes on the heads.
IMO, if youre going turbo route, go with a direct bolt on D66.
I have one on my early 99, and I love it! spools good, has alot more airflow and will support up to stage 2 injectors and 40 PSI.
you can go with a hypermax H2E, but its very expensive and you will HAVE to have a intercooler then. H2E's run upwards of 2500 new for the setup. you'll need injectors if you go that way. Stockers wont spool it well, and you'll burn it up.
Old 08-21-2010, 04:25 AM
I think diesel site sells a set for 1500 or so for the whole kit. I have a SD turbo that needs a rebuild and some uppipes that need new doughnut gaskets. I will sell them cheap if you decide this route.
Old 08-21-2010, 10:02 AM
Will it make a big diff. if i buy used?
Old 08-22-2010, 05:33 AM
the garret Ball bearing turbo is 1499.00 on there
the H2E is at least 2250, and thats with no intercooler piping and such:
http://www.dieselsite.com/index.asp?...ROD&ProdID=322
