Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
Old 05-28-2007, 03:45 PM
eljefe eljefe is offline
Tell me what you think about this combo.
So Im thinkin about puttin gauges(egt, boost, tranny temp) along with an mbrp turbo back 4 inch exhaust, an intake and a dp-tuner on my 95 stroker. Does this sound like a reliable combination? Can I put exhaust and intake on pre-tune and run ok? and last, any experience with cold starts? temperatures nearing 0 but not often?
Last is this a better idea than going with a banks kit? I know this site tends to lean away from banks, but I just want to make sure my truck stays reliable. thanks!
Old 05-28-2007, 04:21 PM
ABOBB ABOBB is offline
Is it even worth it???
I'd say that sounds like a good combo.. as long as you do it in that order. Make sure you have gauges before you add a tuner or chip.
Also, yes, you can add the intake and exhaust without a chip. You will see some small gains just from doing that.
Banks has good products.. they also have high prices. That's just my take.
Old 05-28-2007, 04:25 PM
7.3pôwë®§†rôkè §rt10ëà†êr 7.3pôwë®§†rôkè §rt10ëà†êr is offline
Send a message via MSN to 7.3pôwë®§†rôkè §rt10ëà†êr
Sounds Like A plan Morris!
Old 05-28-2007, 05:28 PM
97stroker_roalin_coal 97stroker_roalin_coal is offline
in the older body styles like your you cant fit a 4'' dp unless you got like a 3'' body lift but a 3'' dp is the biggest you can get. your truck will stay very reliable with an intake chip and exhaust just keep your foot out of it
Old 05-28-2007, 05:53 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Sounds like a good plan to me. 97 is right about the 4" downpipe. Won't fit unless you modify the firewall or do a body lift.
Old 05-28-2007, 05:58 PM
Glasseater Glasseater is offline
yeah that sounds pretty good, injectors'll really liven up that truck!!
Old 05-28-2007, 06:12 PM
Logan Logan is offline
The Fat Mod
That sounds like what I would do if it were my truck
Old 05-28-2007, 06:15 PM
DirtyDiesel DirtyDiesel is offline
definatly wanna get a boost gauge and see wat boost ur gonna be pushin... i know from personal experience that the stock OBS turbo doesnt like much over 30psi and its easy to get that outa one trust me
Old 05-28-2007, 06:18 PM
Interesting...whats the best way to control boost levels? new waste gate actuator? and does any one have any experience with mbrp exhaust? they make a turbo back that goes from a 3" downpipe and then expands to 4 inch to the rear of the truck.
Old 05-28-2007, 06:23 PM
The OBS trucks dont have wastegates on them
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
