too much black smoke - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-31-2010, 06:11 PM Thread Starter
smokin250's Avatar
i just bought a 96 crew cab 7.3 and installed BDP stage 1s TW chip. has a 3" turbo back exhaust and afe proguard 7 intake.
this truck smokes so much i cant stand it. i just bought the chip from tony and my setting.... heavy tow, tow, daily, street, extreme, smoke. the only setting that doesnt smoke really is daily. everything else dumps just as much smoke as the smoke setting itself. i live in california so i cant be running around smoking everyone out.
i thought my turbo might be taking a poop but i have no way of checking. it seems that my boost guage needle flutters really bad starting at 10psi on up and i can also feel the truck kinda flutter when the needle does. is that normal?
thanks for your help you guys rock,
chris
E99 f250 CC/SB 241k miles
procomp 4" lift
35x12.5x20 nitto terra grapplers
6637 mod
MBRP 4" turbo back
superchip tuner
smokin250 is offline
post #2 of 15 Old 07-31-2010, 06:25 PM
no-tel-in's Avatar
gauge flutter typically means you have a boost leak somewhere, Is there soot behind the turbo? (up pipes) and is there a charge side leak? (Y-pipe into manifolds)
The gauge should be smooth, what is your max boost? and coorelation egt's?
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #3 of 15 Old 07-31-2010, 09:02 PM Thread Starter
smokin250's Avatar
i have noticed alittle bit of black right at the flange for the down pipe. on the daily setting it wont boost more than 18 psi and on extreme i have seen 26psi. the gauge shutters so much i cant be a 100% on that. the truck still has a ton of top end power but at lower RPMS it doesnt do so well. would a boost leak cause the truck to smoke as much as it does?
procomp 4" lift
6637 mod
MBRP 4" turbo back
superchip tuner
post #4 of 15 Old 07-31-2010, 09:19 PM
no-tel-in's Avatar
Yes, a leak can cause excessive smoke, a leak will prohibit the turbo from moving as much air as it needs to, so you have extra unburnt fuel, you should probably be seeing a little more boost, prolly near 30 with stage ones and custom tunes.
2000 F-250 4x4 7.3
GTP38r
Adrenaline HPOP
238/100's
post #5 of 15 Old 07-31-2010, 09:23 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
also the hpop,if you have the 15* pump,it cant keep up with the demand.so go with adreniline and it will clear that chit right on up.if you cant wait jus go buy you a 17* from ferd,throw it in there and that will be a lil better.when you do get time send the pump off to joey and get er modded
harley1rocker is offline
post #6 of 15 Old 07-31-2010, 09:25 PM
no-tel-in's Avatar
Yep, that and fuel, if your going that far with an obs I would deff go ahead and do electric fuel!
2000 F-250 4x4 7.3
GTP38r
Adrenaline HPOP
238/100's
post #7 of 15 Old 07-31-2010, 09:28 PM
deff bigger fuel,you already got stage1 injectors,get the full potential out of em with big fuel/oil.have your tw chip retuned when you do this...if you do.
post #8 of 15 Old 07-31-2010, 09:31 PM Thread Starter
smokin250's Avatar
i wasnt planning on spending all that kind of money on this thing. i wanted power like a SD but nothing crazy where i had to upgrade HPOPS and turbos and electric fuel.
why would the truck not smoke on the daily tune but smoke like CRAZY on heavy tow or tow setting? doesnt make sense.
procomp 4" lift
6637 mod
MBRP 4" turbo back
superchip tuner
post #9 of 15 Old 07-31-2010, 09:36 PM
you bought stage 1 injectors cuz,you might as well have bought beans reman fer 120$ those stage 1"s will never see the horsepower you desire without supporting mods,like big oil and big fuel.the only reason your getting the lil extra hp"s your seeing is because of tw's chip
post #10 of 15 Old 08-01-2010, 11:36 AM Thread Starter
smokin250's Avatar
ok drove the truck today on the smoke setting and it doesnt really smoke that much. extreme smokes huge amounts but not alot on smoke. daily seems to be the best one to run around on. anyone know whats up? tried to contact tony but no luck. called a couple times and emailed him with no respond.
today i pulled my computer to check my connections and i found an odd computer in my truck. the diesel shop that installed everything accidentally unplugged my chip with the key on and fried my computer. they ordered me a new one and the truck runs good idles fine but it says its out of a 95 PSD van. the computer code i had was a AUG6 and they put a TEE1 in it? what is going on here? is a van computer compatible with a manual 96 truck? i had tony tune it for the AUG6.
man i really wish some good chip companies were on the west coast. its so hard to wait sending chips back and forth.
procomp 4" lift
6637 mod
MBRP 4" turbo back
superchip tuner
