regulated return
what is the purpose and gains you will see from this and what is the concept behind it. Do they offer it for my 95 powerstroke
yours is a regulated return. but if you switch to electric fuel system you will see better idle and be ready for injector upgrades
cool thanks man.how do you switch it over to electric. i saw you had a diy fuel system
theres sevral differnt setup...pumps/filters/lines...you can use.
I'm using a Mallory fuel pump, that s connected to the feed line comming off of the tank selector, into a fuel filter, then into a fuel water seperator. FWS to a "T" that splits to the fittings in the heads. Out of the heads to an Areomotive adjustable fuel regulator, back into the return side of the stock fuel system . The fuel bowl has been removed. I used braided fuel line that I had sitting around for awhile. You can use the stock fuel lines up to the top of the engine. Somewhere theres a link to using a fuel pump/filter from a 6.0. Last edited by CHUCK; 07-14-2010 at 04:08 AM. |
if you go to post 46 thats where mine starts. easyer to link than repost the hole thing.mine is a single pump set-up.and still use the stock lines.
Electric fuel system conversion - Powerstroke Nation |
Could someone just run an AD2 instead of getting all the different stuff from different places? Then delete the fuel bowl?
micky |
