obs FPR shim mod question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-10-2010, 03:19 PM Thread Starter
StrokedOut154's Avatar
do u honestly need a gauge to read fuel pressure.. cause i have everythin i need to do it but the gauge.. i had to order one.. but for temp can i jus use a cap where the gauge would go.. wud that be alright or is the gauge important so u can see if ur fuel pressure is spikin.. but if it wer coudnt i tell when it was running?
StrokedOut154 is offline
post #2 of 7 Old 07-10-2010, 03:44 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
you might not be able to tell and you could cause leaks. but i never checked, i just slap em in there and let it go
2002 f250 BFT Edition
dereku is offline
post #3 of 7 Old 07-10-2010, 08:19 PM
Nitro41's Avatar
i threw mine in. without checking. but the added pressure is better for my 160 injectors anyways
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #4 of 7 Old 07-10-2010, 09:05 PM
get the fpr housing from bob at diesel orings comes with 3 springs up to 67 psi max pressure cool housing and also get a fitting for easy test and or install of a fuel pressure regulator sending unit for a guage or just manual guage checking...
56.00 for kit 10 or 15 for fitting he gave me one to test out when i ordered a black cps works great I know I have good fuel pressure ..I am going to install a regulated return from riff raff for 130.00 and a high pressure oil crossover so when I rebuild my injectors I know I will never have issues of starving 8 or 1 for fuel .....my number 8 just died on me made truck knock so bad thought a main bearing pooped...scared me to death!
Doing rosewood diesel injector rebuilds ordered em last week 275.00 for entire kit~
scott52575 is offline
post #5 of 7 Old 07-11-2010, 06:44 AM
Guest
Just wait till you get your gauge. I did the FPR shim in my truck a while back and it was worthless. My fuel pressure was already at 65-70 psi. When i did the shim it made it to like 90psi. So thats why i say you should have a gauge, to much fuel pressure can really mess things up.
xxxxxxxSTROKE_THIS_F-250 is offline
post #6 of 7 Old 09-28-2010, 01:29 PM
springturner's Avatar
How do i do this on my 97 and where did you get your te hpop
SPOOLIN STROKER
springturner is offline
post #7 of 7 Old 09-28-2010, 02:04 PM
superduty4x4's Avatar
Terminator Engineering. You have to email him, he doesn't list the modded 17 on his web site.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
