Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
Old 05-21-2007, 07:34 AM
T-ROD T-ROD is offline
What first mods do I do.
I just got a 97 F250 PSD with 99,000 on it. It is my first diesel, I was wondering what the first mods I should do or should I say can do with a typical 25 year olds budget. Thanks for the help.
Old 05-21-2007, 07:40 AM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I would start off with some gauges....EGT (pre-turbo), boost and Trans Temp (for Auto tranny). Then, Intake and exhaust and a chip. After that...your looking at about $1000+ per mod...turbo, big oil, injectors.
Also...other than performance, look at a lift, tires, bumpers etc.
Old 05-21-2007, 09:18 AM
ABOBB ABOBB is offline
Is it even worth it???
I second the gauges first suggestion. You really need to know what your truck is doing before you mod it. By that I mean you need to be able to see what effect your mods have on egt, etc.
You can also look into some of the DIY mods, such as a Zoodad, a Tymar type filter, a fuel pressure shim, and a 10K.
Old 05-21-2007, 10:35 AM
powerstrokin powerstrokin is offline
air intake, and exhaust first
Old 05-21-2007, 07:04 PM
FordNutCase FordNutCase is offline
THEBLUEJET
Yeah i think the backbone too mods with a turbo diesel, to start out with is to get the restriction out of the stock exhaust, let the turbo breath better.
Old 05-21-2007, 07:30 PM
bryanbrown bryanbrown is offline
I'm going with the intake and exhaust first. Just don't start tuning until you get guages. If you look in the mod section, there's a bunch of cheap mods that are easy to do.
Old 05-21-2007, 07:53 PM
PSDfan99 PSDfan99 is offline
blub blub blub
Intake and exhaust can be done fairly cheap. Tymar NAPA filter #6637 is cheap, and if u look around for a turbo back exhaust from our bvendors or like ebay or something, you can get one shipped to your door for like $350 or less. Then the gauges come, then mods that increase fuel!!!!!!!!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
