6.0 Intercooler swap and 6.0 pipes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-10-2010, 09:04 AM Thread Starter
Strokin96's Avatar
Anyone that has installed 6.0 intercooler, did you use 6.0 intercooler pipes also? Or if anyone has, what all was invloved in making them work? Also anyone with picture's of a 6.0 intercooler swap would be great as im hopeing to have all parts to do swap by next week!
Thanks
E-1999 F350 CCLB 7.3 6 spd Ranch Hands F/R, 8" Rough Country on 35x12.50(for now) Toyo MT on 20" Pro Comp, 6637, TS 6 pos custom tunes, 5" Diamond Eye Straight TB 305K and still rolling
Gone: 94.5 F350 5 speed, 35x12.50x18 Trail Grapplers, MT 18" classic locks, 6637 intake, 6 pos chip, 3" DP to 4" straight, Autometer C2 Pyro/Boost, Stage 2's
Strokin96 is offline
post #2 of 7 Old 06-10-2010, 09:42 AM
The 6.0 pipes are way too short to even try it. I put a 6.0 intercooler in my truck along with a 6.0 trans cooler. It is a tight fit but its all in there.
I ordered 3" aluminum tubing from Vibrant Performance online. I used 5 of the 90 degree bends, and 1 18" straight piece. TIG welded everything together. But I also did not go buy a Early '99 spyder, I just cut mine apart and used different pieces of exhaust tubing to make everything fit.
The only problem I am having is that the 6.0 intercooler boots have a ridge on the inside that is supposed to "lock" into the factory pipes that have a groove in them. My pieces are completely flat, and are blowing off above 20psi. As soon as I get some sort of lip on them, all will be good. I should have started with the 6.0 intercooler pipes with the groove in them, and welded the rest of the system to those.
1996 F-350 Crew Cab 2WD
Southern Comfort Conversion
7.3L with an E4OD
4.10 Gears
BFG Commercial Tires-I LOVE THEM
6.0L Intercooler
6.0L Trans Cooler
Upgraded Turbo Intake Housing and Compressor Wheel
DIY Intake with 6637 Filter
3" Stainless DP with 4" Stainless Exhaust
TS 6 Position Chip-Soon to be Reburned
Looking for a set of 3.55 gears if anyone has a decent deal or wants to swap.
brittonracing@yahoo.com is offline
post #3 of 7 Old 06-10-2010, 09:45 AM Thread Starter
Strokin96's Avatar
Awesome thanks man!! I think im going to do what this guy did, but instead use the E99 intake spyder
6.0L intercooler install in '92-'96 body - Fourdoorbronco forums
post #4 of 7 Old 06-10-2010, 10:17 AM
I did pretty much the same thing with the spider, and the pipes. If I wasn't such a cheap a$$, I would have bought the spider for an early 99. If it is in your budget, get it. It is much easier that way. Or if you have a few more dollars, buy the banks piping kit. Looks much nicer, and flows much better.
7.3L with an E4OD
4.10 Gears
6.0L Intercooler
6.0L Trans Cooler
post #5 of 7 Old 06-10-2010, 06:15 PM
Tsgs69400's Avatar
I cut the 6.0 pipes apart and used pieces along with some more I bought at the local swap meet. I made my own spyder and copied the banks design.
Thad
2008 f-350 CCSB 4x4 6.4 Lariat Spartan Tuned, MBRP Duals, S&B intake, egr delete, ccv delete,custom coolant bypass, RF amps, Infinity Component Spkrs, Pioneer Shallow Sub, 13.9sec best
1996 f-250 Extended cab Short bed 4x4 7.3 5-spd, D60, Diamond Eye4" duals, DP Tuner, Stg 1 Injectors, DIY Intake, Custom Regulated Return Fuel System, Adrenaline,billet ww,Comp 910 springs, D66 Turbo, 6.0 Intercooler, SD rear springs,Custom trac bars, Truetrac diff.
Tsgs69400 is offline
post #6 of 7 Old 06-10-2010, 06:26 PM Thread Starter
Strokin96's Avatar
I might do that, use some of the 6.0 pipes like to put on the intercooler and build my own pipe going to the E99 spyder.
post #7 of 7 Old 06-14-2010, 01:47 PM
Tsgs69400's Avatar
ya.it takes time but its worth it. I just picked up a set of 7.3 superduty pipes for $40 saturday. Check your local junkyards.
Thad
