D66: HELP - Ford Powerstroke Diesel Forum
Old 05-25-2010, 05:52 AM
D66: HELP
Just recieved a d66 I bought used online. Looking at it and the stock one is different. The stock one has a square flange where it meets the up-pipes. This d66 is round with a lip meant for a band, not bolts. Am I screwed? Im assuming this exhaust housing is set up for a 1999.5-2003.
Old 05-25-2010, 06:13 AM
keeping this bumped up. Hoping to not have to get up-pipes, manifold etc off a NBS
Old 05-25-2010, 06:22 AM
that is what it sounds like man that you got a d66 for a newer truck.
Old 05-25-2010, 06:24 AM
So I would need to get everything? Up-pipes, pedistal, manifold, and spyder pipe? Nobody makes an adapter to go from the square falnge to the circular one?
Old 05-25-2010, 07:17 AM
You got a D66 for an early-build 1999 truck.
You can actually call Beans and see if they have a turbine housing for an OBS that will fit. However, the center section will also be different as to how it mounts to the pedistal.
I think Beans deals with the D66......
Old 05-25-2010, 07:28 AM
ok thanks ill look into it
