diy injectors - Ford Powerstroke Diesel Forum
Old 05-16-2010, 09:37 AM
diy injectors
if i get the diy stage ones do your injectors have to be running perfect.i just dont want to get in there and find worn out parts and have to buy injectors plus be out the kit.does the kit replace everything or just certain parts? i just need some feeedback on what yall think
Old 05-16-2010, 09:41 AM
diy injectors? where did you find that at?
Old 05-16-2010, 06:26 PM
rosewood diy
Old 05-17-2010, 10:08 AM
r u just sayin u got a tip kit?
Old 05-20-2010, 09:51 AM
is it just the nozzles or plungers and nozzles and such...
Old 05-20-2010, 09:53 AM
stage ones are just internals. It uses the stock nozzles
Old 05-22-2010, 03:51 AM
The main purpose of the DIY Injector kits is to increase fuel flow from properly working injectors. It is very possible, and likely, that you will also find tight tolerances (not good), bad Plunger & Barrels and/or bad nozzles once you inspect them. If your parts are in good shape and your tolerances are good, then just machine the Pistons for more flow, do the overhaul using the parts in the kit and you're good.
Some kits come with new nozzles and I bet you can get a custom kit put together for whatever you want to do. Just send an email to the address you see on the site.
