dual-mass flywheel - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-10-2010, 03:41 PM Thread Starter
OBSPSD's Avatar
dual-mass flywheel
ok so my stock flywheel is gettin worn out but i have a good clutch. does anybody have a cheap dual-mass flywheel thats still good or know where to get the conversion kit to a single-mass for cheap but still have a strong clutch. i have a stage 1 injectors and ts chip so a cheap clutch wouldn't really hold up. any ideas guys??
OBSPSD is offline
post #2 of 4 Old 05-10-2010, 04:11 PM
tjl
tjl's Avatar
My mods are in my sig. I'm running a stock LUK clutch. I've had no problems at all with it. I also pull a 31' camper with no problems either. Unless you're going to be doing truck pulls, a LUK clutch or any replacement type clutch should be ok.
'96 F350 CC dually 5 speed w/short throw shifter, '03 sd intercooler, stage 1 injectors, D66 turbo, 6 POS chip with Tony Wildman tunes, T500 HPOP, CCV mod, gutted EBPV, modded ID
tjl is offline
post #3 of 4 Old 05-10-2010, 07:21 PM
Shade tree mechanic
95dieselsmoke's Avatar
You can buy a single mass flywheel seperately from Valair or south bend. Duall masses are junk and are prone for failure.
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #4 of 4 Old 06-02-2010, 03:54 AM
ATXstroke's Avatar
Get rid of the dual-mass.
1995 F-350 CREW CAB 4X4 5spd 200,000 MILES
VALAIR CLUTCH
Stage 1's (Baby Swamps)
PHP TUNES(STOCK,80,100,120,140,ANTI-THEFT)
DIY INTAKE
FPR SHIM
3" DOWNPIPE
MUFFLER AND CAT DELETED
RANCH HAND FRONT & REAR
WARN HUBS
GOOSENECK
DICK CEPEK DC-1 16X10 RIMS
ATXstroke is offline
