Programmer help - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-05-2010, 02:55 PM Thread Starter
Question Programmer help
Hey,
I've been lurking for a while but this is my first post so please bear with me. I just picked up a 96 F250 extended cab longbed with 150000 miles that is in really good shape and all stock. I've searched the forum and pretty much know everything I want to do for a few extra ponies. I do want to run a programmer, and from researching this site it seems to me the SCT would probably be my best bet because I can change to custom chips (am I wrong) but can't find one for the earlier model ps. Is there another option I could look for ? I pull a 30' horse trailer/camper to riding trips in the mountains of VA and the other guys that I travel with all have newer trucks (all stock) that I would like to halfway be able to hang with without being harassed too badly. Not looking to go overboard, but would like to make as much power as I can without spending more than about $2000. Any help for the new guy would be very much appreciated,
Thanks,
Patrick
hooligan971 is offline
post #2 of 14 Old 05-05-2010, 09:52 PM
i dk if sct sells programmers for the obs truck. but i would go with edge evo for you or maybe a super chip
Don't hate me because I DRIVE A POWERSTROKE hate me because I'm banging your wife
97 powerstroke 240K miles
2 wheel drive to 4 wheel drive swap
gauges
3 DP
5 inch exhaust
H2E
intercooler
stage 3s
910 springs
stealth stage 1 hpop
air dog
regulated return fuel system
TW chip
john woods trans
4.11s rearend
2 kicker cvr 15s
1500 watt amp
kenwood deck
mean97 is offline
post #3 of 14 Old 05-06-2010, 06:37 AM
Seriously, if the truck is stock, get a 6637 filter from Napa for the DIY intake, Get a good 3" downpipe exhaust, get some gauges, then get a Custom chip from someone on here, like Tony Wildman, PHP, Beans. That should burn up about 1200 of your money, and make you pretty happy. If you want more, put in an intercooler, and a set of stage 1 injectors. Then get the chip reburned for the injectors and intercooler.
My mods have followed that exactly to a t. My next step is the intercooler, and injectors. I am very happy with my truck so far. I have a 40' Gooseneck race car trailer that I can put anything in and go down the road pretty easily for hauling 15k. The intercooler is coming soon, cause I am hitting 1200F exhaust gas temp on the hills, and don't want to burn anything up.
1996 F-350 Crew Cab 2WD
Southern Comfort Conversion
7.3L with an E4OD
4.10 Gears
BFG Commercial Tires-I LOVE THEM
6.0L Intercooler
6.0L Trans Cooler
Upgraded Turbo Intake Housing and Compressor Wheel
DIY Intake with 6637 Filter
3" Stainless DP with 4" Stainless Exhaust
TS 6 Position Chip-Soon to be Reburned
Looking for a set of 3.55 gears if anyone has a decent deal or wants to swap.
brittonracing@yahoo.com is offline
post #4 of 14 Old 05-06-2010, 06:54 AM
big sig's Avatar
First off welcome to the org. And I agree with brittonracing. Exhaust, intake, quality gauges like isspro or autometer, and then a custom chip that you prefer. Just talk to each of the guys PHP, beans, TW and go with who you feel more comfortable with. The reason to go with custom chips over edge or super chips is the tunes are made for your truck. You give them the PCM code and you will get the tunes that work best on your truck. If yours is an auto it changes shift points and helps out a lot with towing. Just my $.02
mine
2002 F250 7.3l Powerstroke
AFE Stage 2 Intake
MBRP 4inch Turbo back exhaust straight piped
Autometer gauges z-series pyro, boost, tranny temp
PHP F.U. Chip
4 inch rough country lift, 315/75/16 mud grapplers, and procomp 1069 16x10
dads
2011 F350 SRW CCSB KR 6.7l Powerstroke
FB: Tyler Sigmon
big sig is offline
post #5 of 14 Old 05-06-2010, 05:47 PM Thread Starter
Ok, so with the chip, I send the stock pcm and don't need the programmer ? Whats the average downtime ? What kind of #s are we looking at hp wise with just these mods? Sorry for being a pita, I know everyone gets tired of answering the same old questions but I did several searches and still trying to make the best choices for my app. I already have the parts for the air filter mod and waiting on gauges before I shim the fpr. Next is exhaust. Thanks for the help.
post #6 of 14 Old 05-06-2010, 05:51 PM
Raul@Stealth Automotive's Avatar
def go with a custom tune chip over any off the shelf programmer.. TW, PHP, Matt are all good chips... and i agree with the rest.. intake, exhaust, gauges then a chip.... if you need packaged deals i can set you up with any variation you want
-Raul
Raul@Stealth Automotive is offline
post #7 of 14 Old 05-06-2010, 06:05 PM
big sig's Avatar
Here is a link to PHP.
Power Hungry Performance - Products (Vehicles)
I'm not sure about the downtime. You can see the powergains there. I think I'm going with the F.U. package after I sell my lift kit I just took off of my truck. You don't need the programmer. With the chip you will have a switch in the cab and you can shift on the fly. So say you are driving and want more power you can switch from a econ tune to a race tune. You see a douche and you switch to the smoke tune, and then switch back to the econ tune for the rest of your trip. A chip gives more opportunities and is safer than a generic tune.
mine
AFE Stage 2 Intake
PHP F.U. Chip
dads
FB: Tyler Sigmon
big sig is offline
post #8 of 14 Old 05-07-2010, 08:40 AM
As far as the downtime, I assume you are referring to the time it takes to install the chip in the PCM.
You will not send out your PCM.
I did mine in about 2 hours taking my time, the second time.
The first time I tried to short cut it, and did not remove and clean the PCM contacts.
Remove the PCM from the truck. Then with a BRASS BRUSH, lightly remove the coating from the board, and then lightly "shine" up the contacts. I did not use the supplied scotch brite pad, just the brass brush. It worked great that way.
You can pick your HP settings you want from any TUNER on here, just make sure you order it from a custom tuner. I have a TS performance chip in my truck, and I hate the way it shifts.
Hope this info helps in your decision.
7.3L with an E4OD
4.10 Gears
6.0L Intercooler
6.0L Trans Cooler
post #9 of 14 Old 05-07-2010, 09:14 AM Thread Starter
Thanks for all the help guys. Starting to make a little more sense now. So, I don't actually send the pcm, just the code from the sticker right ? Then how/where is the dial (knob, switch,4/6 pos thingermajigger )connected ?Does that stuff come included with the tunes ?
post #10 of 14 Old 05-07-2010, 12:25 PM
All you need to do is get your 4 digit PCM code, and order your chip from who would would prefer to, like Beans, Tony Wildman, PHP, or who ever. Let them know what you want to do with your truck, current upgrades, and possible future upgrades, so they can tune it accordingly. Give them that code, and what "TUNES" you would like on your chip. They will send you a programmed chip and switch to your door. You then install it in your PCM. The switch connects to the chip that they send you, and everything you need is included.
7.3L with an E4OD
4.10 Gears
6.0L Intercooler
6.0L Trans Cooler
