obs downpipe options - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-21-2010, 07:32 AM Thread Starter
white97350's Avatar
whats the obs downpipe options out there? i have a gt38r on a SD pedistal. the turbo has a 4in outlet then necks down to 3in and then back to 4 then to my 5in exhaust. is there anyway to fit a 4in down pipe in there so i can have it just go from 4in to 5in?
white97350 is offline
post #2 of 16 Old 04-21-2010, 08:24 AM
were there is a will, there is a way !! I would not want to go there myself, the 3" was a PITA, yes It can be done, but I don't know if bending the firewall in enough would work, you may need to cut a section of it out and fab a new sheet metal cupped insert piece. Remember that you need about 1/2" clearance (firewall to pipe) so that you don't have a nasty vibration noise in the cab. this happened to me and I had to take it out and bent the firewall more. Guys on here have done it, maybe someone will chime in with an other idea. Good Luck !!!
97 f-350 4x4 Crew long bed, ZF5, Valair clutch, 4.10 gears 4" skyjacker spring lift, rear shackle flip, nitro 8000 shocks, 33-12.5-16.5 BFG A/T, 3" down pipe, DIY intake, Ts 6 position chip, new ball joints, wheel bearings and warn premium locking hubs,custom leather interior, 190,000 miles
PAYDIRT is offline
post #3 of 16 Old 04-21-2010, 08:30 AM Thread Starter
white97350's Avatar
yea i figured it would take some work. just trying to explore all options.
post #4 of 16 Old 04-21-2010, 08:51 AM
bucwheat's Avatar
What paydirt described is the reason mine is still stock
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #5 of 16 Old 04-21-2010, 09:10 AM
Guest
I have heard to fit a 4" downpipe teh firewall has to be cut out and reshaped to make it fit. Maybe you could fit a 3.5 with beating the firewall up alot.
xxxxxxxSTROKE_THIS_F-250 is offline
post #6 of 16 Old 04-21-2010, 09:10 AM
trevor95f350's Avatar
people have put body lifts in and are able to clear a 4incher but Im not a big fan of body lifts. You would have to do some decent modifying of the fire wall to clear a 4inch down pipe because looking at my 3inch one its already really really tight
10,000 LAKES CHAPTER MEMBER
NEW truck 97 F250 ext cab longbox 4x4 110,000 miles 3in dp, 4in exhaust, ts chip with tonys tunes
OLD TRUCK 95 F350 regular cab long box 4x4 350,xxx miles
trevor95f350 is offline
post #7 of 16 Old 04-21-2010, 09:10 AM Thread Starter
white97350's Avatar
ha. i guess ill have to get creative!!
post #8 of 16 Old 04-21-2010, 09:11 AM
superduty4x4's Avatar
I know a feller on another forum that put a 4" SD down pipe in his OBS and installed a van turbo. He had to do some serious re-shaping of the firewall to make the down pipe fit, and he said if he had to do it over again he wouldn't go there.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 16 Old 04-21-2010, 02:38 PM Thread Starter
white97350's Avatar
after talkin to a few of my buddies.. i think ive come up with an idea to get one in there... ill let ya know after i play with the idea some.
post #10 of 16 Old 04-21-2010, 03:02 PM
I dunno if these will show up or not, if not I'll repost them later.
