someone help me please!!!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-12-2010, 07:09 PM Thread Starter
Stroken97.250's Avatar
I dont know what to do!! i have a 97 f250 and everytime i try puttin a chip on it the wait to start light quits workin and my truck will not start! I need help with any possible problem it mite be any input is helpful! thanks alot!
Stroken97.250 is offline
post #2 of 14 Old 04-12-2010, 07:15 PM
duct tape & zip ties
bigcountrysg's Avatar
Did you clean the PCM contacts? Did you clean them to much and damage them? What chip is it?
Need more info, but it sounds like you either cleaned the terminals to much and the chip is not making good contact. Which could be causing your problem.
Or you did not clean them good enough and you are not getting good contact. Which could also cause your problem.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 14 Old 04-12-2010, 07:15 PM
ADMIN AND TECH
SCUFFY828's Avatar
have you cleaned the conection real good on the pcm
ITS STOCK
SCUFFY828 is offline
post #4 of 14 Old 04-12-2010, 07:52 PM Thread Starter
I think dirty pcm is my problem i need to clean it up really good! ands done it with a bully dog 40 hp chip and a ts 6 pos chip i need to clean my pcms and try it.. what should i use to clean it up?
post #5 of 14 Old 04-12-2010, 07:57 PM
5spdpowerstroke's Avatar
if your real careful not to take too much off a razor blade will work, i've also used a pencil eraser and that worked really well too, also fill out your sig so we know what your runnin
Jesse
proud NRA member
SOLD (and missed
'97 F-250 5-speed
3in" down pipe into 5" exhaust
diy intake
blullydog 6-pos chip
auto-meter ultra-light boost & egt guages
stage 2's from industrial injection
custom made ladder bars
NEW TRUCK 2001 CUMMINS, 5spd swap, FASS dual filter, 4" TBE, edge juice w/attitude CS
5spdpowerstroke is offline
post #6 of 14 Old 04-13-2010, 06:30 AM Thread Starter
ill prolly try the eraser trick should I use dielectric grease or electric contact cleaner>
1997 F250 heavy duty 7.3 4x4
3 inch down pipe 3 1/2 inch straitpipe. 4 inch rough country suspension lift. 315/75 tires.fpr shim. diy intake autometer gauges (trans temp, boost, pyro). custom front bumper with fog lights. TS 6 stage chip. Jensen dvd head unit. custom side marker lights. custom steps. 16x8 machined xd hosses. bushwacker street flares. light bars under the dash.
post #7 of 14 Old 04-13-2010, 11:15 AM
A brass brush works very well, and will not take off the tin! Ask Bill at PHP
1996 F-350 Crew Cab 2WD
Southern Comfort Conversion
7.3L with an E4OD
4.10 Gears
BFG Commercial Tires-I LOVE THEM
6.0L Intercooler
6.0L Trans Cooler
Upgraded Turbo Intake Housing and Compressor Wheel
DIY Intake with 6637 Filter
3" Stainless DP with 4" Stainless Exhaust
TS 6 Position Chip-Soon to be Reburned
Looking for a set of 3.55 gears if anyone has a decent deal or wants to swap.
brittonracing@yahoo.com is offline
post #8 of 14 Old 04-13-2010, 08:58 PM
tneibling's Avatar
Stroken97.250 bought my OBS...red and silver 97 F250 reg cab 4x4 auto 4"lift 35's with big downpipe to straight pipe and tranny, boost and pyro gauges on pillar...I don't know what else he's done to it since he bought it
My truck:
99.5 F250 4x4 Ex cab long bed
7.3, zf6
Swamps 175/30's
Cales tunes
DIY Intake & Zoodad mod
Muffler Delete
DIY CCV mod
Foil Delete
DIY leveling kit
AIH delete
Autometer Phantom II Boost and Pyro
Luk Clutch
Dad's Truck:
2001 F250 4x4 Ex cab short bed
7.3, 4R100
Muffler Delete
Foil Delete
DIY CCV mod
AIH Delete
DP Tuner F5
tneibling is offline
post #9 of 14 Old 04-14-2010, 06:39 AM Thread Starter
I cleaned up the pcm very well and tried the ts 6 pos again and still no wait to start light and it will not start im startin to think its a problem in my computor
post #10 of 14 Old 04-14-2010, 08:16 AM
does it act correctly without the chip being plugged in?
Jesse
proud NRA member
SOLD (and missed
'97 F-250 5-speed
diy intake
