Fpr shim
Hey I wanna do a fpr shim on my 1995 ford powerstroke all you do is stick a bb in it? And you stick a fpg on it. Would that make more black smoke since it would have more fp?
nope........
little better idle maybe. Make sure if you do it that you use a guage. If it exceeds 70 psi you should take it out.
Only thing you can do to make any power and have it smoke good is bigger injectors.
A custom tuned chip will get you some but its not that much. |
Ya I have a ts 6pos but I'm gettin stage II diy injectors n adrenaline hpop
check your fuel pressure at idle and if its low, around 50 psi or so i would try it.
But when i did it made my Fuel pressure jump about 20 or so I would also reccomend getting a Fuel pressure gauage that goes in your cab with those injectors on a stock fuel system. With my stage 1's i have seen down to around 45 psi on a WOT run. |
