Excessive Black Smoke
I just installed my dp-tuner chip with the 40hp tow, 80hp economy, and 120hp settings and it smokes like crazy even at half throttle or less. I have a 96 OBS with 3" downpipe, 4" straight pipe, afe 4" filter, 6.0l intercooler, Beans stage 1 160cc injectors and the chip. Before I installed the chip the pickup wouldn't smoke at all even with the injectors and now it seems a little excessive to me (half throttle can make the car behind me dissapear even on 40 tow). I was doing some research and saw that clogged intakes and leaky intercooler pipes could cause excessive smoke. So I cleaned my intake, checked out my turbo and smoke tested my intake system and found nothing wrong. I was wondering if anyone had any other ideas? Should I have my intake system pressure tested? Thanks, Jon
What for boost numbers do you see?
Ever since I did the intercooler I have had bad turbo lag but its much better with the chip but at 2200rpm im a bout 10psi up to 27psi at around 3000rpm
10 seems low for 2200 rpm
Yea I'd pressure test it to see if there is a leak. What kinda EGTs do you see Last edited by jesilvas; 04-05-2010 at 04:31 AM. |
The little bit I have been able to open it up I have not hit more than 1100 degrees
Where is the EGT probe at? DP or manifold?
well u wouldnt have gotten any smoke or power out of stage ones without a chip, since the chip is what makes stage ones give power and smoke, ur turbo might be bad
Talked to a local diesel shop and they agreed with me that I was getting to much fuel on top end talked to DP today and they are going to fix it for me.
to much fuel???? why dont you leave it alone and then try to make your truck burn it all! maybe throw a lil propane on that bad boy
