Help: swapping parts from 94 to 97 - Ford Powerstroke Diesel Forum
Old 03-29-2010, 05:03 PM
OK im hopefully buying a 97 real soon. My ?s are: The stage 1 injectors im running in my 94, can I swap them into the 97? From what I understand the 97's were split shot, so what do I need to do there? Also, I have a 17* HPOP in my 94 and it was modified to correct the drain back issue. Does this need to be redone to put it in the 97 or will it be ok as is? Thanks!
Old 03-29-2010, 07:25 PM
The injectors will be fine, at most you would have to get custom tunes and tell the tuner that they are single shots.
Old 03-29-2010, 07:40 PM
Your injectors with be fine unless the new truck is a cali model. If you got the drain back modded you should be fine i would think, but im not positive.
Old 03-30-2010, 03:09 PM
cool thanks guys
Old 04-17-2010, 11:40 AM
ok so I can run the single shots in the 97 with custom tuning so does that mean i have to have custom tuning in the 94 to run with the split shots? I hope not...
Old 04-17-2010, 07:32 PM
is your 97 a cali model? if not then its has single shots, i know my 97 had singles
Old 04-18-2010, 12:01 PM
o cool. I would imagine it is not a cali model. Is there an easy way to figure it out? Does the title show?
Old 04-19-2010, 04:08 PM
bump... just need to know for sure if the injectors are the same. thanks
Old 04-19-2010, 04:22 PM
i'm not sure how to tell, maybe pull a carfax to get its origins, just an idea, where did you get it? i doubt its a cali truck
Old 04-19-2010, 04:42 PM
I bought it in Iowa and he claimed he was the second owner. I will check out carfax thanks! So for sure then: If it is NOT a cali truck the injectors will be the same as the late 94, correct?
