what is a exaust pressure control valve,NEED INFO GUYS!!!!1
THROWING THAT CODE and i dont know were or what the hell that is
EBPV (Exhaust Back Pressure Valve) Suppose to close to help the engine warm up faster. Most guys just delete them when they go bad. It won't hurt anything to have the code. You would have to replace the sensor and probably the tube (clogged with carbon) to fix the problem.
im also gettin the intake air temp circuit high out put code,and i have got the 6637 napa mod..im also gettin the (internal control mod KAM error) would this make the truck miss fire,because im gettin a big miss fire man,ive replaced all the gasket harnesses and one of the injectors is sittin in there a lil crooked,
no smoke wat so ever,and its a auto trannie,when im ideling you can tell that its a miss and when going 35 mph it feels like your in 5th gear,i have to hit the OD button to get down in 3rd till i get up to speed so it will plane out
A lot of times you have some smoke when there is a miss. Did you replace the harnesses under the valve covers and the valve cover gaskets? You might have to take it and have a cylinder contribution/buzz test to find out where the problem is.
yes i have replaced the harnesses,and only the glow plug (prong) of the harness was messed up,look,there is a injector sittin in there a lil **** eyed,well you can tell cuz its not straight up and down like the rest of em
Sitting in there twisted or actually leaning different?
yes its sittin in there twisted,and alll the ones on the driver side are stock,except that one,previous owner musta replaced that one,i did feel it and its tight but i kno those things somtimes gotta be pried out,i didnt get down on it and really hard,you think i shud pop that sucker out? and whats the maintanace pocedure on these things? if i pop them all out and clean emm err replace o-rings and such wud that help,err is ther somthin i cud do to em when i have out?
