Injector swap - Ford Powerstroke Diesel Forum
Old 03-19-2010, 10:22 PM
Injector swap
Hello all, I am changing out the injectors on my 96 f250. I am having trouble with the #8 injector, due to AC stuff in the way. Is there a trick to get that injector out without having to remove all the stuff? Any help would be appreciated. Thanks - Chris
Old 03-24-2010, 08:40 AM
pull the insulation down thats on the heater core box (i think thats what you call it) and you'll be able to remove a little vacuum resivour which will give you enough room to pop that last injector out.
