INTAKE AND EXHAUST 97 PSD - Ford Powerstroke Diesel Forum
Old 03-15-2010, 10:16 AM
Question INTAKE AND EXHAUST 97 PSD
Hows it going everybody? im new to the site and i was trying to get some input from you guys if you can help. I have a bone stock 97' f350 crew cab long wheel base 2wd and i was wanting to put a cold air intake, exhaust, and bully dog 6 position chip. Can someone please recommend a good intake, also i dont want to completly replace my exhaust what do yall think about punching out the catyletic converter and possibly just removing the muffler. I dont want it super loud i just want it to sound more "THROATY" if you will.
Any input would be greatly appreciated.
Thanks Alot!!!!
Old 03-16-2010, 06:16 AM
Thinking about just cutting off my cat. converter and replacing with a section of pipe and leaving the stock muffler and exhaust pipe! What do yall think about that? Will it sound ok?
Old 03-16-2010, 06:21 AM
you can just cut of off, it will make it the turbo whistle louder but it wouldent be as loud as if it were straight piped and ive heard good things about tymar intakes but i cant afford anything like that so im going to use some PVC pipe and a NAPA filter haha
Old 03-16-2010, 06:45 AM
As far as the intake goes i am looking at an AFE 2. but they have 3 styles a dry and 2 other ones take a look at the link below and let me know which one sounds best
Cold Air Intake System Stage 2 Ford Trucks- 94-97 V8-7.3L (td-di) 54-10792 - aFe Power Diesel&model=F-350&year=1997&diesel=true&brandID=53
Old 03-16-2010, 06:51 AM
Full A-Team Member
Man I guess if you got the money.
Cost $60ish at Napa for great filtration and better flow.
Get:
6637 air filter
4" hose clamp(or 2 smaller ones put together)
45* 4" exhaust elbow
Install:
15 minutes....Remove factory air box. Attach 45* elbow to air filter. Slide elbow into existing intake tube to turbo. Tighten clamps and your done.
Old 03-16-2010, 08:06 AM
im gonna get the s&b intake. looks cool and i like how it still uses the factory under hood scoop and the fender so u still get nice cool air and no air comen from inside the engine compartment! and for sound iuno. im new to all of this. but i will have my exhaust mon!! i can let u know then
Old 03-16-2010, 09:47 AM
That factory "underhood scoop" is a big bottleneck. You can't really beat the NAPA 6637 filter for money and airflow and ease of install.
For the exhaust, cut out your cat and muffler and replace with straight pipe. It doesn't make it obnoxious like a gasser it makes it loud at just the right times.
Old 03-16-2010, 11:39 AM
IF I DELETE MY CAT AND MUFFLER WONT I HAVE TO UP THE SIZE OF MY TURBO BECAUSE I WILL HAVE NO BACK PRESSURE AT ALL? THATS WHY I WAS THINKIN I SHOULD LEAVE MY MUFFLER ON
Old 03-16-2010, 11:47 AM
Nope. These engines don't like all the backpressure that a gasser does. Probably 75% of us are not running cats or mufflers. Some even run 6" straight pipe exhaust so don't worry about backpressure.
Old 03-16-2010, 02:04 PM
KOOL THANKS WELL IM CUTTING THE CAT OFF TOMORROW MORNING AND BLANKING IT WITH A PEICE OF PIPE. I WILL SEE HOW IT GOES FROM THERE.
