300 hp?
hi everyone im new here so im just trying to get some info. well just bought a 97 F350 and was wondering if it was possible to make 300 hp with stock sticks and turbo? i plan on putting on an intake, a single stack, and a tuner. i wondered if it was possible. also could you guy give me what you did to get that number or close to it. thanks
The only way your going to get to 300 with stock injectors and turbo would be an aftermarket HPOP and a 1.0 turbo housing(in addition to what you've already mentioned) Go with a custom program chip (wildman, or beans) that will put you knocking on the door of 300 depending on what shape your injectors are in. Wouldn't be a bad idea to go ahead with the "10k" mod (search it on here there's a lot of threads on it) another very good not too terribly expensive mod would also be an aftermarkert fuel system (will give you a better cleaner fuel flow and prolong the life of your injectors)
Hope that helped and didn't pop your bubble |
Dont do a resistor mod. ICP gets crazy when you do that.
98cc's of fuel will not get you there. Need stage one's
x2..stage 1's will do it with just a chip, exhaust and intake..need guages.
[QUOTE=BambiBasher;1739306]hi everyone im new here QUOTE]
congrats on the new purchaseWhat ball park of HP would you expect with a TW chip, intake and exhaust? Would you need the 17* HPOP or would the above 3 mods be enough to get you close? |
hang with me I have the DP magazine with the chip tests in it, I will get you the #'s for TW's chip
k...here we go, I will give the info on the truck also.....
97 F350, stage 1 injectors, intake, exhaust (4"), CPR fuel system, intercooled, stock turbo, stock HPOP, 305 tires and 4.10 gears.....
#'s 313 HP, 681 lb-ft torque there were others in the testing but this gives you the general HP, basically if you want 300 rwhp, stage 1 injectors and custom tunes with intake/exhaust |
[QUOTE=TxAG'97;1741086]RWHP would be 225ish with those mods.
