OBS downpipe - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-21-2010, 07:01 PM Thread Starter
OBS downpipe
Whats the easiest (brand) downpipe to install on an OBS? I'm expecting firewall mods but is one easier than another?
2005F250 is offline
post #2 of 6 Old 02-21-2010, 07:54 PM
ryandamo's Avatar
they are all pretty much the same, you wanna get a 2 piece one, since that will be the easiest, but most are 2 piece.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 6 Old 02-21-2010, 08:41 PM
Full A-Team Member
Fordman247365's Avatar
^^^^ What RD said.....and there are no 'easy' ones they are a PITA to put in. Agreed on the 2 piece
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #4 of 6 Old 02-21-2010, 08:49 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
They aren't that bad with a 2X4 and a 12LB sledge hammer.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #5 of 6 Old 02-21-2010, 10:22 PM Thread Starter
Any write ups here with pics?
2005F250 is offline
post #6 of 6 Old 02-21-2010, 10:27 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
That's funny!!
I disconnected the stock pipe from the turbo and exhaust then used a long pry bar to bend the firewall outta the way using the stock pipe as a leverage. Torched off the top part of the pipe and pulled 'er out the bottom. Worked pretty slick.
Don't need pics bud...all you need is caveman skills GIT 'ER DUN!!
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
