transmission temp. - Ford Powerstroke Diesel Forum
Old 02-04-2010, 07:38 PM
Send a message via AIM to 350dieselsmk
transmission temp.
Hooked my gauges up tonight. think i might have messed the tranny probe up a bit. ran the truck for about 10 minutes and was reading 210. When i put the new tranny plug in i wrenched on the wrong hex head and spun the inner piece around, looks like some Teflon or something came out? it continued to rotate inside. not sure if that is a normal temp or not. i wasn't beating on my truck or anything i think the plug might be bad after the inner spun. any ideas?
thanks
Will
Old 02-06-2010, 08:03 PM
sounds like the sender is shot.you can just buy the sender.210 is on the HOT side of things.
Old 02-07-2010, 10:59 AM
yea 210s sounds kinda hot, and it doesnt take much to screw temp senders up, luckily if you buy just the snder, there usually cheap
