So I did the 10k mod.... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-04-2010, 01:46 PM Thread Starter
Full A-Team Member
Fordman247365's Avatar
I did the mod with 2 different resistors, a 10k and a 4.7k(these were the only 2 that my r-shack had)
The 10k did nothing, i am going to try it with a new resistor to see if the resistor was bad, but when i put in the 4.7k the idle 'loped' and it made a ton of low end power and had throttle response up the rear. the wierd thing is if i would take off driving it with the 4.7k it would be fine till about half throttle and the it wouldnt go, i could floor it and nothing would happen, i actually think it would start to slow down. if i feathered the throttle it would pick up and run 50-55 mph, but again if i floored it, nothing.
What I am wondering is do i have a bad ICP or HPOP going out, or is it normal for that resistor to make it un-drivable? with nothing on it the truck runs fine...or seems too. I changed the oil in the injection system yesterday and thought maybe it was low and thats why it would fall on its face but i checked that after it sat without running for a half hour and the level was fine, in fact it was full to just under the plug.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #2 of 3 Old 02-06-2010, 05:27 PM
check this out, probably whats happening
forget the 10k mod, use the all new 22k! - Page 3 - Ford Truck Enthusiasts Forums
dump valve in you HPOP probably switching on which dumps pressure.. meaning no power.
FordXtreme is offline
post #3 of 3 Old 02-07-2010, 11:27 AM Thread Starter
Full A-Team Member
yeah, hooked it up the way he does it(IN A DIFFERENT POST ON THAT SITE) and i have been playing with it, 4.7k i just tried seems to work good, tried 14.7k and it was too much, truck was a dog....gonna play some more with it. hooking it up his way there is no idle lope.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
