pos still wont start!!!! - Ford Powerstroke Diesel Forum
Old 01-24-2010, 02:16 PM
ok i need oppenions on why my truck just died like you turned the key off.no it didnot sputter or choke it just cut off.i have went threw 3 cps sensors checked all gounds cleaned the screen in the filter element cranked the truck over with the filter out and it is pumping fuel into the element went over as much wireing as i can see changed both the batterys. im a lil pissed at it and this is my last desparet outreach for help before i go blow all my money on expert help.
Old 01-24-2010, 02:20 PM
duct tape & zip ties
remove your chip, see if it starts. If it does then the problem is your chip. If it doesn't try and hook a scan tool to it. If it does not connect, your pcm maybe bad.
Old 01-24-2010, 02:22 PM
Pointless Poster
. the chips can do unexpected things.
Old 01-24-2010, 03:10 PM
have you checked your IDM?
Old 01-24-2010, 04:30 PM
ok the tw chip i had in there made the truck not start awhile back so i took it out and put the bullydog back in and it started so takeing the chip out was the first thing i did no difference. i did hook a scaner to it and it said error but i thought if the pcm was bad the dashlights would act differnt.and the idm and pcm was my next thought can i pull them out and take them to ford to be tested?
Old 01-24-2010, 04:35 PM
does the wait to start light come on when you are cranking? Have you checked all your fuses?
Old 01-24-2010, 04:40 PM
yes it does and yes i have checked fuses and relays
Old 01-24-2010, 04:41 PM
but will ford test my computers if i take them to a dealer?
Old 01-24-2010, 04:43 PM
They will if they have the truck with them. In other words you need to take your truck to the dealership.
Old 01-24-2010, 04:52 PM
well damn if i did that i would just let them fix it. if the scan tool said err and the dash lights were acting normal could it still be the pcm or idm and how would i know which one?
