17* pump
I know there are tons of posts about the 17* HPOP, I am just curious if there is a write up on installing one on a 96?
Also, where is the best place to buy one? I don't plan on going with anything bigger then stage 1's so all I should need is a stock 17* pump. Thanks, Justin |
Matt P had a right up on a 17* HPOP install but nothing about changing the guts
Here you go 17* HPOP install in an OBS by Matt P |
I would contact Joey at Terminator Engineering. I am very happy with his modded 17* in my truck, and only plan on stage 1's as well, but the pump will support more if you change your mind.
Joey is a great guy to talk to and will answer your questions. |
I would try to find a good deal on ebay then send it to joey at terminator engineering like said above. I found one on ebay for 150 shipped and only had 70,000 miles on it!
there is one on ebay right now for $50
not hard to do. Good upgrade over the *15 pump. I run Stage 2's with a stock *17 pump and everything is good. Maybe eventually I'll get it modded.
I don't really see a need to have to spend the extra money to have one modded as I know im only going with stage 1s.
I think just a stock 17* should be fine. |
wasn't meaning you should get it modded sorry. I was saying maybe I'll get mine modded sometime. But next time I do anything with the HPOP system I'll probably be either going Stealth Pump or running 2 *17 pumps
That wasn't directed towards you, I was just saying in general I should be fine with a stock 17* and stage 1s.
I would just do an adrenaline. Its only like 400 bucks.
