17* HPOP info - Ford Powerstroke Diesel Forum
Old 01-12-2010, 09:40 PM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
17* HPOP info
I am buying a 17* its stock right now....possibly will be getting modded before i throw it in though!
What are you guys seeing for difference between the 15* and 17*?
What am i going to feel if i just simply replace the 15 with a 17... remember i have stage 1's
Old 01-13-2010, 06:10 AM
You might have a little more topend. depends on the condition of your old pump.
Old 01-13-2010, 06:12 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
If your 15* is in good shape you probably won't see much of a difference.
If you were running split shots however, you would need the 17*
Old 01-13-2010, 06:48 AM
Electrical Ogre
The big thing will be no more CEL and defueling due to a lack of high pressure oil.
Old 01-13-2010, 07:10 AM
Better fuel atomization..ie; less smoke
Old 01-13-2010, 09:09 AM
Okay and the pump will get modded by terminator engineering before i put it in.
So i'll be running a modded 17*. Should help out quite a bit on top end
Old 01-13-2010, 09:16 AM
Too cool for school
Not as much as your hoping it will.
The 17* just maintains oil pressure better on the top end.
If you feel a performance gain, its because your injectors are now at their full potential.
Old 01-13-2010, 09:45 AM
Which i know they aren't right now. And they definitely wont be once i put 80% nozzles on!
So this will help once i go bigger. And it will keep me from throwing codes right now. Thats exactly what i wanted
Old 01-13-2010, 09:48 AM
I was running stage 1s for a while before I put my 17* hpop in and I noticed a decent difference in the top end. It WANTS to continue pulling all the way through the gears now instead of dropping out. I think youll be impressed.
Old 01-13-2010, 09:49 AM
thanks man! With it modded it should be even slightly better. You should look into getting yours modded. Its $50 to get it done and it will nearly compare to the Adrenaline afterwards!
