Electric Fuel system build for WVO - Ford Powerstroke Diesel Forum
Old 12-14-2009, 10:06 PM
Exclamation Electric Fuel system build for WVO
I am going to be running WVO in my truck and need to know exactly how to put this electric fuel system toegether.
Do I put the fuel filter/water seperator before or after the pump?
Also do I put the fuel heater before or after the pump?
How many micron filter before and after the pump?
Anything pointers are gladly appreciated!
Mark
Old 12-14-2009, 10:18 PM
Send a message via ICQ to greatwhite7.3
Fuel System
this might help i'm not sure sorry if it doesn't. look towards the bottom it has good info.
Old 12-15-2009, 10:12 AM
Thanks any other reccomendations, tips, or things I should get.
Specifically Im looking for answers on micron ratings and where to install the water seperator and heater.
Mark
Old 12-15-2009, 01:37 PM
If I do dual fuel pumps how are they run in a series?
Mark
Old 12-15-2009, 10:43 PM
ask the biodiesel forum here, its alot more than just adding a pump to run it. it needs to be heated and filtered till its clear
Old 12-24-2009, 09:26 PM
Mark
put the filter before the pump.. i recommend a racor fsf1000
the heater is before the pump and the filter.. i have dill dabbled w/ both.... go with a hott foxx..
always go with a filter that is less micron then your stock filter.. mine is 2 micron in the fsf1000.... this fuel/water seperator is also heated.. thats why i like it..
i have had this on my truck for over two yrs.. no problems yet!!
