Glow Plugs - Ford Powerstroke Diesel Forum
Old 12-07-2009, 10:39 AM
Glow Plugs
is there a "better than stock" glow plug on the market?
Ive heard that Borg and warner were supposed to heat up faster but there all around 10 bucks a pop.
just wondering if anyone has any personal experience with different glow plugs.
Old 12-07-2009, 11:13 AM
bump anyone know
Old 12-07-2009, 11:50 AM
I was told to use Beru/Motorcraft plugs & nothing else due to other brands swelling & getting stuck and/or breaking when trying to remove.
Old 12-07-2009, 12:58 PM
hmmm okay thanks
Old 12-08-2009, 03:18 AM
I'm waiting on some Welman plugs, the top aftermarket producer.
I know of only 2 good ones: From Ford and the Welman.
Old 12-08-2009, 01:55 PM
Send a message via AIM to kw900driver
Bosch is by far the best in my opinion, just put them in mine and a crank and a half when it was 20* out and it fired, before i would be about 6 cranks. plus if you do the plugs replace the relay with a Stancor one instead of the crappy one they give you from Ford or an autoparts store
Old 01-10-2010, 08:04 PM
KW900driver, is that with your truck plugged in or just a completely cold 20* start? My truck wont fire up when its this cold when it isnt plugged in. If i plug it in for so much an an hour it fires right up.
Old 01-11-2010, 04:52 AM
thats with it unplugged, if it gets really cold i will cycle the key a couple times and it ill fire right up. plugged in and it fires right away.
