MODS
what else can u do to make more hp besides the basics chip turbo injectors hpop and intercooler i need some input guys i mean that cant b everything
come on guys need some input here
Well, looking at your sig, here's what I would change/ add.
If you're going to go to Stage 2 or 3 injectors, then I would add ARP head studs first. (and maybe a cradle) Also, if you're going to go to BIG sticks, then opt for a much larger HPOP, like an Adrenaline, or you can look into this puppy. http://www.dieselsite.com/index.asp?...ROD&ProdID=950 I say this because you need HPO to pump the fuel. Also, if you're going to be upgrading to BIG sticks, I would definitely opt for a bigger turbo. (maybe an H2E) You could also look into a different fuel system to feed the beast. ![]() That's all I can come up with, but I know there's other guys on here who're making BIG power, and they could tell you much better than I, what you'll need to do. (Especially Marty) mike |
nitrous propane, intercooler, water/meth
Horsepower wise yeah thats about it. Fuel pump upgrades are another one. Different pistons, Rods and things too. But those wont give
i keep seeing people talk about a craddle/griddle what is that for, i also saw a pic of one but have no idea what its for?
basically a girdle is a part added to the bottom end to help keep high HP engine blocks from cracking
I think new cams and springs can also be added.
More than anything, the biggest thing is to just feed the motor more fuel. (and to have all the proper mods to support feeding the motor max fuel) mike |
I am running the following...
Chromoly Pushrods Comp 910 valve springs 400/600 Swamps Injectors Swamps Gen 3 Oil Swamps BFH turbo H2E Mounting System H11 Headstuds My own Fuel System Factory Forged Rod Block I also have a BTS to hold the power and suspension modifications to plant the power. |
well here is my plans.
17 hpop sd intercooler twor dp chip head studs a turbo idk which one yet stage 3 diys im thinkin a fass fuel system sno water meth stage 3 valair clutch a bigger cam if thats possible and new internals. what kind of hp u guys think ill be pushin with all of that? i cant spend a ton of money but a decent amount. |
