hybrid injectors????
not planning for them any time soon but had some questions. first why are they called hybrids? what do u need on ur truck to run them? i see people running them on a stock hpop....how is that? i have a electric fuel system and was wondering if my fuel system witha 17 hpop would i be able to run them?
thanks |
The biggest advantage with Hybrids is they push a LOT of fuel and you can run them with a stock 17* HPOP.
What makes them a Hybrid is the Plunger & Barrel assembly inside. Think of the injector as a large syringe, and these P&B's are much larger in diameter, so you push more fuel per stroke because there's more volume to push. The oil side of the injector doesn't change so you can use a stock 17* HPOP. Make sense? What else do you need? Well, you don't need anything. But if you want to take full advantage of the power they are capable of, then you need a very large turbo, head studs, fuel system, good tunes, built trans/clutch, and so on... |
so if i run them with a 17hpop and a d66 will they run pretty nice?
Yup but to take full advantage of them get everything I have in my sig plus a nice turbo. Thats is whats holding me back oh well
D66 and Hybrids...not a combo I'd use! You will also need a $1k clutch.
i wouldnt run hybrids with a d66 buts thats just me.
how much power gains compared to stage 1's with my set up (intercooler soon to come)
also are they smokey like stage 1's? |
238 cc Hybrids are well known to be in the 550 hp range with all the supporting mods. Your Stage-1's with stock turbo etc now are around 300 hp. |
