schwitzer S3A800 turbo??? - Ford Powerstroke Diesel Forum
Old 11-13-2009, 02:32 AM
I got a brand new turbo off a mack truck. Do you think my good ol stroker would be able to spool it itself or should I be looking into a compound setup. im switching up to stage II's and the diesel site oil pump over the winter if it would help.
Old 11-13-2009, 03:16 AM
Berm Buster
You better just get some hybrids. Mine as well go big.
Old 11-13-2009, 03:23 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
Good luck getting that thing mounted
Old 11-13-2009, 03:29 AM
Berm Buster
You should post some pics up.
Old 11-13-2009, 04:13 AM
subscribed
Old 11-13-2009, 05:45 AM
its probably going to have a very large turbine housing and i doubt it would spool worth a crap on a 7.3. what displacement is the mack truck engine?
Old 11-13-2009, 08:36 PM
728 CU 12.1 liter. My buddies dad works in a machine shop so All I have to do is cut a T6 flange and a T3(i think) and Make a pipe for inbetween. I thought of compounds but that puts me into open class for pulling. I plan on at least stage II's with the adrenaline and the overdrive unit to feed the injectors. I can get a smaller hot side for that turbo. Nitrous may be in my rig's future to get that turbo spooled.
Old 11-14-2009, 04:35 AM
Too cool for school
Thats about twice the displacement man, its gotta have a gigantic hot side on it.
Good luck with whatever you do though
and by the way, the flange for out reucks are a T-4
Old 11-14-2009, 07:39 AM
Sounds interesting. I think it would be more work than its worth because alot of things would need to go right to mke it work well. Turbo are not just bolt up the biggest one you can spool and go pull.
Old 11-14-2009, 07:41 AM
Hey man I see your from Ohio... where at in the state? Check out the Ohio chapter on here if you plan to stick around the org..Buckeye Power Strokes. We have a get together coming up. Welcome to the ste
