The sound of air - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-10-2009, 08:01 PM Thread Starter
The sound of air
So I have DYI intake, 3" DP 4" cat back, 6 position TS chip.
I installed the chip and the exhaust a day apart (chip first then exhaust). Even before the exhaust after putting in the chip i now "hear air". Is this normal after increasing the boost level? I have owned many of turbo cars(gas ofcourse) and you can hear some air. I checked the "Y" pipe and the rubber seals, the are all good. Are there any other places to check boost leak or as I asked, is this normal to hear it more vivid now?
Thanks
Charles
1999 F-350 4 door Dually
TS 6 position chip
4" Straight back
SpudZooka is offline
post #2 of 9 Old 11-11-2009, 07:40 AM
cndrm's Avatar
Well, I'm guessing that when you say "hear air", you're referring to the sucking sound of the turbo? If so, then yes, it's normal. My VW is turbocharged, and you can hear the turbo sucking air pretty decent, but keep in mind, these trucks aren't VW's. We're not talking 1.8L, we're talking 7.3L. 444 cubic inches of big block motor. These motors consume A LOT of air. And I'm imagineing that it's even more prvilent with good, custom tunes. I wouldn't worry about anything. If you really want to check for boost leaks, then DieselSite has a product that you plug into the compressor side of the turbo, and you then pressurize it with an aircompressor. If there's a leak, you'll hear it.
mike
Don't burn your bridges, you might have to cross them again in life.
Don't sugar coat things. It covers up the taste of real life.
Providentia Remedium Belli
Early 1995 F-350 Crew Cab Long Bed
33" Hankook RT03 Muders
DIY Intake w/ Napa 6637 filter
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Upgraded gear reduction starter
Bypass Oil System
Bypass/ Coolant filter system
Gauges
Built Tranny
cndrm is offline
post #3 of 9 Old 11-11-2009, 09:24 AM Thread Starter
Well, I dont think its so much sucking of air. It almost sound like a boost leak, the pushing of air. I could be wrong, and you are right, these's engine require a lot of air in general. I'll listen again today to pin point sucking of or pushing of air. Thanks for the suggestion/idea.
Charles
TS 6 position chip
4" Straight back
post #4 of 9 Old 11-11-2009, 09:48 AM
cndrm's Avatar
Charles, No problem. I personally think that the bit that you can get from DieselSite is pretty cool. Plug it into the compressor side of the turbo, and pressurize everything to 10 or 20 psi to bring out boost leaks (at proper pressure) The big issue, is to check it without, then it's going to be pretty tough. With their rig, the motors off, and everything is quite. It's just kinda expensive if you ask me.
mike
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Bypass Oil System
Gauges
Built Tranny
cndrm is offline
post #5 of 9 Old 11-11-2009, 10:13 AM Thread Starter
Ya I was looking at that piece, it is niffty but I do agree it is kinda expensive for what it is. Anyways, I'll be leaving in a bit and hopefully it is more of a sucking sound vs pushing.
Charles
TS 6 position chip
4" Straight back
post #6 of 9 Old 11-11-2009, 10:48 AM
redline73's Avatar
That sounds like turbo surge to me. The Compressor wheel is actually choking out and reversing flow because it can no longer take in any more air, it sounds like a pst pst pst pst when the boost is climbing?
Mine makes this noise when towing heavy loads or pulling hills empty. There are 3 ways that im aware of to cure this
Wicked Wheel install, its a compressor wheel that is a stock compressor wheel off of a early 99 PSD
ported compressor housing- its a 4" inlet instead of the three, and its a larger housing I believe all together
Larger Turbine housing-This info came from brian at BTS, he said that this is the only mod you would need to do to totally cure turbo surge, he said to go with a 1.00 exhaust housing
The wicked wheel is the cheapest of the three
http://www.dieselsite.com/index.asp?...PROD&ProdID=47
Ported Shroud Compressor Housing
1.0 AR Turbine Housing
-01-F350-Lariat-CCSB-4"lift-35"Xterrains-BTS Trans-Tuned by Cale
-98 Big Tex 40' gooseneck
-93-GMC-Topkick-Caterpillar 3116/Cummins 6BT swap-
Too many other daily drivers to mention
redline73 is offline
post #7 of 9 Old 11-11-2009, 10:57 AM
FENKER's Avatar
obs have the wicked wheel. thats why we never have surge
1997 f250 HD ex cab sb with southbend 450hp singlemass clutch, 6" lift with 35"s, 3 1/2"down pipe with straight pipe, afe stage 2 intake, tw chip, ccv mod, 17* hpop, 120v idm,vegistroke system V3. (AKA electric fuel for diesel and veg side)
UPCOMMING MODS:diy fuel bowl delete,fass pump for diesel side, stage 2's, d66 turbo or modded h2e
no parking cone at stanford university
FENKER
FENKER is offline
post #8 of 9 Old 11-11-2009, 10:59 AM
redline73's Avatar
I just realized that i spent that post on a OBS thread, i didnt realize it until just now. I need to stop hittin the new post button and just going on a clicking frenzie.
post #9 of 9 Old 11-11-2009, 05:06 PM Thread Starter
Well I desided to double check before I left that there were no visable signs of boost leak ( boots, Y-pipe). Well I suppose maybe I put the clamp down to far so when it built boost after while it slid down and left a nice big opening. I took it off and cleaned it about 2 days ago when I did my exhaust, guess I didn't tighten it enough or had the clamp to far down the boot. O well, guess I shoud check and double check the simple things before asking questions on the forums lol.
Wierd thing is tho, the truck actually seems not as powerful in the low end after I fixed it... Wierd... My only assumption is it was able to spool up really quick (little resistance because air could escape). I dunno, maybe its just my imagination.
TS 6 position chip
4" Straight back
