Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
Old 11-09-2009, 02:22 PM
stackedpstroke stackedpstroke is offline
Compound turbos
I have a 1996 f 250
I have a few mods. Im at about 430 hp i have a stage 2 tranny.
Im wanting to run compound stock turbos. And a ic I have a few questions
is there a pipe for the intake manifold that i canbuy or will i have to fab one ?
How do i run the oul to the secont turbo?
I dont want to mess with mounting it under the hood. So im going to
bolt it to the frame right After my dp
Old 11-09-2009, 02:46 PM
Strokeorcroak Strokeorcroak is offline
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
what are your current mods getting you to 430hp??
Old 11-09-2009, 02:58 PM
Cory S Cory S is offline
Old 11-09-2009, 03:15 PM
choupique108 choupique108 is offline
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
i was wondering the same thing
Old 11-09-2009, 03:16 PM
jesilvas jesilvas is offline
Yea gotta know all watcha got so the guys can help.
Old 11-09-2009, 04:39 PM
430 is quite a big number for a 7.3... thats a pretty spendy setup he's running. He must have an H2E or bigger already to push those numbers.... and he is doing it with no IC?
Old 11-09-2009, 06:05 PM
mods
injectors.
upgrade high pressure fuel pump
progammers
17*hpop
intake
exhaust
propane injection 8 psi constant over 2000 rpm and
35psi race propane shot (diy)
ccv mod
fpr shim
quick spool turbo wheel
turbo makes 28 psi
stage 2 tranny
valeo high preformance clutch
i run royal purple oil also.
this is a estimated 430 my buddy had his truck (95psd) dynoed and he put down 385 with no turbo mods and no propane so i'm pretty sure im atleast in the 415 area but like i said its estimated
but my question was is there a pipe i can buy to put a ic on a 96 or will i have to fab my own?
and how do i tap the oil to run oil to the new turbo?
Old 11-09-2009, 07:50 PM
I thought maybe they did have some IC pipes for the OBSs but if you're wanting a big one you might have to fab your own.
Not sure about the oil
Old 11-10-2009, 01:36 AM
Matt P Matt P is offline
a truck
What size injectors?
Programmers? Your not stacking are you? bad idea if so. what tunes are you running
Stock turbo with a quick spool wheel I take it? If so there is no way you are making 430hp. Not on a stock turbo
And making compounds out of two stock turbos would be a massive waist of time. Not to mention two stock turbos would never even work in a compound setup, you cant use two of the same exact chargers, not to mention two stock ones.
Old 11-10-2009, 07:06 AM
Yes stacking
stage 2
and quick spool with a 1.0 ar exhaust housing
Also. How would it not work ?
I would put a y pipe at my ic inlet and pipe mboth of them into it
2 turbos each making 20-30 ps. Would be twice the boost wouldnt it?
Twice the air atleast
