Downpipe leak
So I just finished installing my turbo back exhaust, 3" downpipe 4" all other. I am having a %$#^ of a time getting the downpipe to clamp to the turbo. I have it almost all the way on there but I have a slight leak still.
What will happen if I am unable to get this all the way on? Will it cause high egt's? You cant hear the leak, you can feel it a bit if you put your hand over it. I am stil going to fight with it but I would like to know if I should expect any damage if it is run like that or if it ever slips up while driving after I get it fixed. Also, any idea's on how to get it on there easier? Thanks Charles |
No the downpipe will not cause EGT issues..
The only issue would be soot blowing out the opening and you'll be smelling exhaust.. |
Well thats a good to know that the egt's wont do anything. Any suggestions as to how to get it on better, any tricks or just time/patience?
Thanks Charles |
having someone hold the dp while you put the bango clamp on makes it a lot easier.
Quick question did you bend up the fire fall at the location ware the pipe comes down? For some reason I have put these pipes in and had to bend more in for some then others. On my truck I had to use a sizzer jack to compress that area enough. Lt looks like have put a dent in that area. it did not cause any problems, but the pipe slide right in. This allowed for the pipe to be clapped on just right with out any leaks. Hope this helps. later on
that could be it. I spent like 3 to 4 hours on making sure that it was bent for correct positioning of the pipe. I spent more time putting the pipe back in forth in and out then I did anything else. but it paid off. let me know if you need any more help
So I drove it today and yea, the downpipe viberates agianst the truck bad. So do I need to pound out the firewall near the bottom of the truck, like near the bell housing of the tranny *edit*.
If so, what suggestion would you use to pound it in? Cant really get a hammer or a mallett in there. I can get a pry bar but what can I safely pry against? Last edited by SpudZooka; 11-08-2009 at 11:12 AM. |
Try to find a small scissor jack. Wedge it in between the point you bent in, and the bell housing on the tranny. The fire wall should bend in and I would push it in 3 inchs or so. you will also need to move it a few time to get the whole area bent in. I hope that this helps. Let me know how it goes.
Great thanks, I will see about getting one tomorrow or so. I presume the downpipe has to come out again
.Well, I'll let you know, Thanks again. |
