cummins - Ford Powerstroke Diesel Forum
Old 11-04-2009, 07:27 PM
cummins
has anyone on this forum done a cummins swap? i read about it on a web site and im thinkin about doin it. id just like to hear how it was from another person. was it hard? how long did it take? how much money? i wanted to make power outta my 7.3 but for the price it seems like i can get more outta the cummins performance wise, thanks for ur help
Old 11-04-2009, 07:29 PM
Depending on what you can get an engine for, expect anywhere from $5000 to $10000 to do it yourself. Destroked.com has all the answers you seek.
Old 11-05-2009, 08:37 AM
New engine mounts
trans mounts
driveshafts front and rear due to different case lengths
Made up rad mounts
Air to Air mounts
Usually bash firewall for clearance
Need a dana 60, they are 1250+ lbs
Wiring is eary for mechanical
Engine and trans price aside, it can be done nicely yourself for under 2500.
Old 11-05-2009, 10:09 AM
You dont need a Dana 60...a Dana 50ttb will be good enough. I know of many trucks with snow plows on them with a TTB setup, it will be fine.
Old 11-05-2009, 03:13 PM
Location: lake county california, 2hrs north of san francisco
I did the conversion on my buddy's 92' crewcab f-350 and we used fordcummins.com. they had everything we needed to do the conversion.
Old 11-05-2009, 07:01 PM
i have a dana 60 in my truck right now its a 350, now would it be good to use a dodge transmission and transfer case that goes on the motor, or should i get the adapter plate for an e40d out of my truck? ive seen bad things happpen to dodge transmissions
Old 11-05-2009, 07:27 PM
We used the ford tranny and transfercase, however the kit say's beat the firewall in a little and to push the tranny and transfercase back towards the rearend and cut 3" out of the rear drive line and add 3" to the front drive line. That way the cummins will fit in the engine bay. How ever we didn't want to cut the drive lines so we left the tranny in the stock position and pushed the radiator out the front 2" and rebuilt the radiator support and grill to make room. Where in the prosses of geting a 2" body lift to make extra cleaarence for the back vaulve covers. We added electric fans for clearence. I will post pictures soon. the total cost was around $7200 when said and done; motor, fuel/oil filters,adadpter kit(motor mounts, adapter plate,custoum pilot bearing, custoum exaust manifold, voltage regulator, air intake, directions on how to) intercooler, custom exahust and intercooler tubes.
Old 11-05-2009, 08:09 PM
ya i want to do it in a few years that for sure. then put my 7.3 in my dads truck
Old 11-06-2009, 08:12 AM
You could get away but your front end would wear out a lot faster due to the wieght, a dana 60 would handle the wieght betterr.
Old 11-07-2009, 08:02 AM
im in the process of lookin for a 12 valve now anybody have any idea where i could find one? point me in the right direction and who wants to buy a 97 powerstroke with 138k on it with a zf5 tranny?
