Manual To Auto Conversion. - Ford Powerstroke Diesel Forum
Old 11-04-2009, 05:25 PM
Well the time has come, Im going to pull my ZF and replace with a E4OD.
Not only am I doing that. But I am putting the ZF in the truck that the E4OD came out of.
Here is both trucks. (Big_red_stroker) and my truck. Big_red_stroker... trevor is on deployment so I got both truck to work on.
Ill try to take pics along the way of the process.
Old 11-04-2009, 07:36 PM
the big red stroker wants a standard?
Old 11-04-2009, 10:56 PM
Send a message via AIM to tsteel
Good luck Dallas!
Old 11-05-2009, 01:06 PM
hell ya i want a 5 speed! i miss shifting gears. and them E40Ds are not made for pullin
Old 11-05-2009, 06:19 PM
Few hours of work pulling the auto out. Weather turned at really started raining, called it quits for tonight.
Pulled the Skid plate, both front and rear drive shafts, disconnected wiring harness, removed starter, unbolted TC from flex plate, shifter linkage, tranmission mount, removed all but two bolts holdin the cross memeber up. Tomarrow It should be out.
Old 11-05-2009, 06:44 PM
have fun need to lift it lot easier to work on
Old 11-05-2009, 06:48 PM
my truck is lifted. you can sit under it and change the oil
Old 11-05-2009, 06:50 PM
you might be a red neck if you need a ladder to change you oil
Old 11-05-2009, 06:55 PM
lol my truck is not as big as your bud
Old 11-05-2009, 06:57 PM
dude it go like a 2in lift on it no biggy hey dose you buddy like his snow kit
