busy weekend - Ford Powerstroke Diesel Forum
Old 11-01-2009, 03:18 PM
shaking things up
busy weekend
well i finally got around to moding my truck a little more lol got my intercooler and hpx line installed with a hot side map mod truck runs really well now i could really feel the dif even with stock injectors
Old 11-01-2009, 07:29 PM
what is a hpx line?
Old 11-01-2009, 07:33 PM
a truck
congrats man, i should have the D66 off this weekend so you can add that to your list
Old 11-01-2009, 09:50 PM
Electrical Ogre
Originally Posted by STROKE_THIS_F-250 View Post
what is a hpx line?
A crossover line to connect the head oil rails. Remove a plug from each head and cram it in between all the other stuff.
Old 11-02-2009, 03:55 AM
Jethro...I have looked/searched...but, what is the hot side map mod? I assume it is connecting your map sensor to the hot side IC tube/turbo outlet...could you please explain why this is better? I am going to be installing an IC in Dec/Jan when home on leave and would like to know. Thanks
Old 11-02-2009, 05:21 AM
shaking things up
SWEET thanks matt
Old 11-02-2009, 05:23 AM
shaking things up
yeah it is taking the map sensor off the intake runner and moving it to the hot side of the ic. from what i have read it reads more boost sooner thus delivering more fuel to the motor faster. seems to me like it works and makes sense
Old 11-02-2009, 09:18 AM
what is a hpx line?
High Pressure (oil) Crossover line.
Take from the Dieselsite-
The High Pressure Oil Crossover Line connects the left and right High Pressure Oil rails together. This allows the computer(PCM) to monitor the pressure of both High Pressure Oil rails, therefore producing a much more even fuel distribution by balancing the oil pressure between the two rails. The line also acts as an accumulator, resulting in less pressure spikes in the system. The result is a smoother idle and all around better running engine.
Old 11-02-2009, 02:51 PM
Sounds like i should put it on my to do list.
Old 11-02-2009, 02:56 PM
shaking things up
had mine made at a local shop for $20 special thanks to rroning for the fittings on the end total cost was $25
