ZF5 to E4OD swap info - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-25-2009, 09:33 AM Thread Starter
ongoingshow's Avatar
What does a guy all have to take off of the ZF5 truck to swap it to the other truck? Tranny, T-case, crossmember, clutch assembly, pedal assembly, tranny wiring harness, computer, drive shaft, front drive shaft too?? Did i miss something?
97 F250 zf5spd, Dana 60 front, 4 link rear air ride, dual terminator setup, beans dual fuel kit, 6pos chip by beans, 300cc injectors, modified H2E, headstuds, valve springs, 6oh intercooler, SBDD. All together =:pullover:
ongoingshow is offline
post #2 of 5 Old 10-25-2009, 09:57 AM
shaking things up
jethro's Avatar
the flywheel will also need to be remved
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 5 Old 10-25-2009, 06:05 PM
Guest
Also will it work from a extendedcab shortbed to a Single cab long bed?
xxxxxxxSTROKE_THIS_F-250 is offline
post #4 of 5 Old 10-27-2009, 07:41 PM
Guest
Anybody that has does done a swap. Do you know if the swap will work or have any advice?
post #5 of 5 Old 10-28-2009, 03:51 PM
Gauge cluster, steering column or hack off the shifter BS, Iknow the ECUs are different but IDK if it matters if you're swapping to a stick. At least there's just a plate bolted over the hole for your master cylinder. I haven't done the swap, but I'm in the middle of putting an auto gasser cab on my 5 speed.
suva is offline
