hpop gasket - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-23-2009, 01:30 PM Thread Starter
shaking things up
jethro's Avatar
hpop gasket
where can i find a HPOP gasket
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #2 of 5 Old 10-23-2009, 01:33 PM
FORDBOY24's Avatar
there o-rings...ford dealership is the only place is where I got mine
2008 F350 EC/LB 6.4 FX4
CAMB MOTORSPORTS
FORDBOY24 is offline
post #3 of 5 Old 10-23-2009, 01:38 PM Thread Starter
shaking things up
jethro's Avatar
ok i wasnt sure if ne one else sold them for less so the hpop does not use a gasket is uses an oring to mount to the motor?
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
post #4 of 5 Old 10-23-2009, 02:26 PM
BRS
No, it does use a gasket in the front. I think I bought mine at NAPA. Metal, and about 4"x6" as I recall
Ben
Early '99 7.3L F-350 SRW SC LB
DP Tuner (NS,Stock,HI 1200, DT,40T,80T,80E,120R,140A), Coolant Filter, External Trans Filter, 6.0L Cooler, JW Stage I Trans, Dipricol Optix Gauges, AFE Stage II, MBRP 4" Turbo Back, ProComp 4" Lift Front, Skyjacker 6" Rear Leafs w/ 1" Block, 16x8 MT Classic II's
BRS is offline
post #5 of 5 Old 10-23-2009, 02:59 PM Thread Starter
shaking things up
jethro's Avatar
ok i thought it was a gasket not an o-ring
389.14 HP 726.00 TQ
3 in DP
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
jethro is offline
