e350 wich chip to use(programer) - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-22-2009, 11:51 AM Thread Starter
i got a 97 e350 i dont want to make a lot more power but i want to give it more towing capability and also be able to tro out the **** of the van if a litle honda boy come on my side
i already got
4 inch exausth
egt
boost gage
oil presure gage
truck its stock
i saw alots of people speacking about total diesel perfomance that the better way to go? or the only way to go!
i can get edge also bd and hypertech
tanks alots
chummey is offline
post #2 of 13 Old 10-27-2009, 05:42 AM Thread Starter
i just got a evolution its make a big diference but when i reech 23 psi
check engine come on and my watchdog told my i dont get more then 10 psi after that until the ligth come off i try to read the code but the cumputer dont give me any trouble code
i just send a email to TW chip
can somebody help me to know what gone a be the next part i really need to put there please
i read alot aboute the hpop did i really need one ? can somebody explaine to me how come that high presure oil pump play in the game with the injectors i dont understand that
chummey is offline
post #3 of 13 Old 10-27-2009, 07:27 AM
highland512's Avatar
Dump the edge and look into getting something custom tuned. Wither it be from TDP or from one of the many other chip tuner. Look up DP tuner, Power Hungry Performance, Swamps Diesel and many others. I have saw some real disasters resulting from the edge, its very cruel to the transmission. Good Luck!
-Matt
'04 350
ZF6
SCT 5015
highland512 is offline
post #4 of 13 Old 10-27-2009, 07:36 AM
You injectors are hydraulically activated (using engine oil). That High Pressure Oil Pump pressurizes the injectors with engine oil. The pump that is put in the older trucks (and vans) is what's called a 15 degree pump. It doesn't pump as much oil as a newer 17 degree pump. When you demand more oil than the pump can supply, the computer throws a code (P1211 - ICP below desired mount). ICP is Injection Control Pressure, it's what ford calls your high pressure oil. Basically it won't hurt anything, but it will throw a code. IF you get a custom chip from Tony Wildman (Total Diesel Performance), it will make the code go away automatically. It won't change the fact that you are using all the high pressure oil you have.
One thing that the Wildman chip will do for you is use that oil more effectively than a edge evolution will. My brother used to run a Superchip tuner in his truck, and he got codes all the time. The performance was okay, but not great. Now he runs a TW chip, and the power is much better, and the thing doesn't throw codes.
The most important thing that TW chip will give you over an Edge is the transmission tuning. Edge is famous for it's poor transmission tuning. It *will* wreck your transmission. TW actually tunes your transmission to handle the extra power safely.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #5 of 13 Old 10-27-2009, 07:47 AM Thread Starter
wow tanks alots man now i really understand that
if i just want to get it trouble free the thing i need to do to be SURE just put a TW chip and a a better hpop gone a be the best bang for the buck if i only want to be SAFE wich hpop i can put (for less money but safe)
i bougth this van because i need to tow my trailer with my offroad truck and towing a big f250 on the trailer its not the most heavy low this kind of truck can see but its heavy
chummey is offline
post #6 of 13 Old 10-27-2009, 07:52 AM
I would do the new pump first, then get a TW chip that is programmed to work with the new pump to take advantage of it.
Or you can get a TW chip first, and then have it re-programmed when you get the pump upgraded. re-burns of the chip are either really cheap or free. Getting it re-burned is no big deal, you just have to send it off for a few days.
post #7 of 13 Old 10-27-2009, 07:56 AM Thread Starter
wath im gone a do im gone a order the chip for the pump and im gone a buy the pump today
but witch pump do you think im gone a need the adrenaline look very godd but litle pricy
can i get something more cheeper or that the way to gay if its the way im not gone a wait and order this one BUT if i can save litle money and get something good for me WHY NOT
btw tanks alots you help me very bad
chummey is offline
post #8 of 13 Old 10-27-2009, 08:00 AM
Adrenaline pumps are a nice option, but kind of a waste on a van. That is what some body with a 17 degree pump upgrades to when they run out of oil pressure on a newer truck. For you, simply getting a 17* pump will do a lot for you.
Just buy a pump from any truck or van after 2000, and it will be a 17* pump.
post #9 of 13 Old 10-27-2009, 08:00 AM
Just find one out of a supper duty in the junk yard! Make sure it's at least a 2000( I think) or newer.
-Matt
'04 350
ZF6
SCT 5015
post #10 of 13 Old 10-27-2009, 08:07 AM Thread Starter
i try to order my TW chip rigth away but they ask for the number on the cumputer but i didnt know wich one
im gone a call the scrap yard rigth away to find a pump 2000 and more 7.3 only ?
chummey is offline
