which hpop - Ford Powerstroke Diesel Forum
Old 10-19-2009, 08:12 AM
which hpop
looking to get a new 17* hpop for my truck. Found two options. one from diesel specialsts for 559.50 including a new ipr and one from dieselsite adrenaline for 589. i would prefer the adrenaline but do i also need to replace the ipr valve?
Old 10-19-2009, 08:14 AM
You'd have to talk to dieselsite about if you need an IPR with it on the adrenaline. That would be the better option as it's going to flow a bit more oil.
Old 10-19-2009, 10:19 AM
I know that just like Ford, we recommend you change the IPR when changing a pump out. This eliminates alot of grief and troubleshooting from bad o-rings etc. with the old IPR. However, we do send out new o-rings for the IPR with each Adrenaline so that at a minimum you can change those out.
Read the instructions here: https://www.dieselsite.com/pdffiles/...structions.pdf for Bob's recommendations.
Don't forget about the rebuilt IPR that DieselSite sells as well. You can find that here: https://www.dieselsite.com/index.asp...ROD&ProdID=952
Old 10-20-2009, 08:34 AM
id recommend a dieselsite adrenaline, i installed one on a friends truck and it made a significant improvement over the tired 15* hpop.
Old 10-20-2009, 02:14 PM
my buddy is goin to be upgrading his HPOP on his super duty.
would it be worth it to pick up his stock superduty HPOP for cheap? anything other then a direct swap invovled to put it on my truck?
Old 10-20-2009, 03:49 PM
Might be a good option. Even for a core it might be a good idea.
Since neither party seems to be a sponsor the Dieselsite pump I'm sure is a good pump or they wouldn't sell it. But give Terminator Engineering a call too. Nice to know your options.
Old 10-20-2009, 04:05 PM
Coal Rolling = Posing
One more vote for the Adrenaline. Especially if you tow.
It made a WORLD of difference towing.
Old 10-21-2009, 03:11 PM
Feedback Score: 5 reviews
Fill out your sig and we can answer your question
