stage 2's - Ford Powerstroke Diesel Forum
Old 10-02-2009, 05:44 PM
stage 2's
hello i am interested in doing stage 2 injectors in my 97 automatic. i have intake, exhaust, and gauges. i am wondering what turbo would be best for this, what hpop would be best, and what automatic tranny you guys recommend. i am going to do fuel system, custom tuned chip, and other neccesary supporting mods. i believe i will need head studs and an intercooler. any info appreciated. thanks.
Old 10-02-2009, 10:14 PM
Electrical Ogre
The 17* HPOP in the Superduties will be sufficient for oil supply. Even the stock OBS one (15*) may hold up if it's in good shape. If oil delivery is insufficient, the truck will simply defuel when wound up on a hot tune, and set a DTC for HPOP pressure, you won't break anything. An intercooler will help keep the EGTs in check for sure, and is worthwhile if you plan to do lots of towing. For a turbo, you'd be looking at the D66, H2E or modified H2E. There is some debate over the need for headstuds, but installing them is good insurance. Installing Comp Camps 910 valvesprings will prevent valve float at higher boost levels as well, and can be had for under $100.00
Old 10-03-2009, 04:57 AM
thanks alberta 7.3 i am kinda new to the whole diesel thing, but i love the idea of a big quick truck.
Old 10-03-2009, 07:21 AM
Electrical Ogre
The 2's will wake up your truck BIG TIME.
Old 10-03-2009, 09:37 AM
does anyone have horsepower and torque numbers for a good stage 2 setup?
Old 10-03-2009, 09:55 AM
Feedback Score: 5 reviews
420 and 950 +- here on OLD tunes..little more I hope once the modded H2e gets on with TW's new tunes.
Old 10-03-2009, 10:17 AM
a truck
I have some stage 2s for sale just to let you know, asking 950 plus your stockers
Old 10-03-2009, 05:55 PM
Send a message via AIM to AntiqueIronHauler
I currently have 1's in mine that only have about 2000 miles on them. Ive been thinking about stage 2s but then someone told me the only difference in the 1's and 2's is a bigger nozzle, if that the case can i have mine lasered out or is there more to the 2's than that?
Old 10-03-2009, 08:29 PM
a truck
nope difference is that 1s use stock nozzles and 2s use a 80% or 100% over stock nozzle
Old 10-03-2009, 08:40 PM
I hope your transmission is up to it. As well as the rest of the drivetrain.
