Does anybody know anything about this compressor wheel? I removed it from a ups truck here at work the seals in the turbo are shot and leaking but it has this compressor wheel in it.
What exactly would I be risking? Seems like an upgrade going from a cast wheel to a billett wheel.... it came out of a tp38 these are dinosaur trucks made out of international chassis and these are the older 7.3 as they have a mechanical fuel pump where all obs 7.3 powerstrokes have them. So I'm not sure what I would be risking by lightening the rotating mass of the stock turbo and adding more blades as to what is already in the truck.
You can't just change the compressor wheel on a obs without removing the turbo there's not enough room to remove the compressor housing. Even if you could just change the wheel if the turbo is high mileage you could very possibly wipe the bearings with the extra load you are going to add to them.
The problem with the impact is it shocks. The shaft and could put hair line cracks in it. not so much bearing problems
And it comes off easily with a ratchet anyway
I wasn't thinking so much about using a impact. I am saying with the billet wheel the turbo will build more boost therefore more load on the turbo bearings. You might get away with it with stock injectors but to me installing a 360* bearing kit is cheap insurance.
I know I'm running on borrowed time with my stock turbo with 1.0 housing. I have the billet wheel and 360* bearing kit sitting on the bench and want to get a ebpv delete pedestal.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
