fuel system help
i needed to get some info from some of you guys with modded fuel systems
if you dont know already i had had some serious problems with my truck and its lead me to belive its the fuel system is bad and if i am going to have to replace it im going to upgrade it and put something better on. i need some help on picking and choosing for the money. ![]() what kinds have you used, have had good things to say about it and how they hold up. thanks again! |
Stock superduty electric fuel pump, wire it in yourself on a 30 amp relay.
Dual filters, water/fuel seperator and a 2 micron. I can get you the pump with the fittings in it you need or $40, the filter heads from napa are 35 each, filters are 15 and 20, and he pushlok is going to be around 100 bucks. You'll need a regulator... try ebay or I can get them for a couple hundred. You'll need associated fittings 100-150 bucks. |
what kind of fuel pressure should i be seeing... even for my truck stock i asked my buddy to check the fuel pressure and im waiting for a callback but i just wanted to get a round number to see if its even the fuel system
and if it is the fuel system ill have to take you up on the pump and stuff. ill let you know what i find out |
If you're going to do it... do it right the first time and get rid of the POS fuel bowl.
right now will the superduty one elimnate the fuel bowl?
i just want to fix it and fix it right so this dosnet happen again |
Tims I/C Page example |
You can do the superduty pump and eliminate the fuel bowl.
You're looking at probably 500 bucks in parts + install. |
Wow, that guys website, and write ups are great. Tons of really awesome info there.
mike |
fuel system help
Today I got in the SD and I see that I have a 1/4 tank more fuel than yesterday.Tomorrow I'll open the fuel bowel and check the fuil for contaminants.Depending on what I find :it maybe in need of a flush.A good fuel anaylsis would be helpfull. Does anyone know you can analize fuel????????????? All Im saying that corrosion of fuel, contaminants,water,fungi,or rust is flushable. I don't know why my tank is filling up over night.I wish it was diesel. |
sounds like youve been visited by the fuel fairy
