Scanners - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-16-2009, 11:26 AM Thread Starter
cndrm's Avatar
Scanners
What's everybody using to scan/ read the codes on their OBS trucks? My truck (1995) has the OBD I connector, which leaves A LOT to be desired. My local Ford dealer wants $190 to read the/ any codes. (I told them I'd pass on that)
So what's everybody got?
mike
Don't burn your bridges, you might have to cross them again in life.
Don't sugar coat things. It covers up the taste of real life.
Providentia Remedium Belli
Early 1995 F-350 Crew Cab Long Bed
33" Hankook RT03 Muders
DIY Intake w/ Napa 6637 filter
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Upgraded gear reduction starter
Bypass Oil System
Bypass/ Coolant filter system
Gauges
Built Tranny
cndrm is offline
post #2 of 18 Old 09-16-2009, 06:31 PM
ricksstang's Avatar
Reading Codes
I use a VIN Locked Superchips tuner. Cant use it to tune the truck so at least it is good for something. By the way, the ODB II Code readers that are at Auto Zone and Advance will not work on 95 and earlier strokes. Even though they will plug and act as though they work.
Rick
Dirty South Strokers
95 Crew Cab Dually PSD
3"dp into 4"exhaust
Gauges: Boost, Trans Temp, EGT
K&N Intake
Performance built Trans
Edge EZ
ricksstang is offline
post #3 of 18 Old 09-16-2009, 07:21 PM
My truck is a 97 so it has the OBDII connector that works. I used a superchips tuner for a while, still have it stuffed behind the seat for those emergency situations, now I use AutoEnginuity on my laptop... dunno quite why yet, but it's there.
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #4 of 18 Old 09-17-2009, 03:41 AM
TxAG'97's Avatar
OBD Diagnostics, Inc. - OBD2 All-In-One Scan Tool w/ USB
ODB11
I have a co-worker that useses this for his mini van and he was giving this scanner a good review - I am not sure if it will work for my truck.
I just recently had to replace my oil temp sensor and I had to pay for the use of the shop's scanner. So, long story short a $27.00 sensor cost me $200. Now I am in the market for a scanner.
Along with cndrm I would like to know what is the best purchase? I don't want any more stranded on the side of the road, tow, and a $100 scan all for a $30 sensor.
Thanks for the help.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip, Stage 1's, BTS
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear Replacement Clear Headlights
Ruff Tuff Seat Covers, Westin Nerf Bars
16x10 Pacers W/315 75x16 Duratracs
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
TxAG'97 is offline
post #5 of 18 Old 09-17-2009, 03:47 AM Thread Starter
cndrm's Avatar
I've done quite a bit of research on the OBD I and OBD II systems. My truck a '95 model, made (12/ 1994) has the OBD II plug, but the problem is, while many vehicles of these model years will have the OBD II "PLUG", they do not have the OBD II "PROGRAMING". This means you cannot use a standard OBD II scanner. You have to get a scanner that has the OBD II plug, but is designed to read OBD I programming.
mike
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Bypass Oil System
Gauges
Built Tranny
cndrm is offline
post #6 of 18 Old 09-17-2009, 04:15 AM
ryandamo's Avatar
i had this same problem back in 2000 whe my cam posisiton snseor went bad, and before it was a known problem. I brought it to the dealaer because it would just die on the highway, they said they had to put a $1000 computer for a 97 in it so they could even diagnose it and turned out it was that stupid sensor. Truck did run and start better tho
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #7 of 18 Old 09-17-2009, 06:23 AM
mike
I thought the trucks with this issue just needed to get their computer re-flashed to be able to use the OBDII as OBDII.
you can pickup a locked Super Chips tuner for your truck to use as a code reader/clear codes, however you will have to look up the code so it means something worthwhile, but still it may only narrow it down slightly. The main reason I got the AutoEnginuity is so I can read sensor data and do actual troubleshooting rather than parts replacing, also with AE you can run diagnostic tests. I understand that there is a Scan Gauge out there that does the same thing, just out of your gauge pod.
Big Bird is offline
post #8 of 18 Old 09-18-2009, 06:50 AM Thread Starter
cndrm's Avatar
Big Bird, I've read that the 94 and 95 trucks can be reflashed to think they're 96's, but I'm kind of sceptical. Personally, I'd rather just get a scanner, or computer program that works with what I already have. (I'm very farmiliar with the issues that old electronics and old software can come up with)
So, maybe the AutoEnginuity is the way to go. I'll look into it. I have a laptop, so hooking up via USB port, is no big deal.
mike
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Bypass Oil System
Gauges
Built Tranny
cndrm is offline
post #9 of 18 Old 09-18-2009, 07:01 AM
trevor95f350's Avatar
Mines a 95 with an OBD II plug and Ive hooked it up to the scanners at school with no problem and as far as I know it runs the OBD II but I guess I never really got to into it, I just used it to read codes not run tests.
10,000 LAKES CHAPTER MEMBER
NEW truck 97 F250 ext cab longbox 4x4 110,000 miles 3in dp, 4in exhaust, ts chip with tonys tunes
OLD TRUCK 95 F350 regular cab long box 4x4 350,xxx miles
trevor95f350 is offline
post #10 of 18 Old 09-18-2009, 07:04 AM Thread Starter
cndrm's Avatar
Well, from what I've gathered, I have the OBD II style plug (16 pin), but the 94-95 years only ran OBD I programming. (so therevore, an OBD II wouldn't work) But to be honest, I've never plugged an OBD II scanner in to see if it would work.
mike
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Bypass Oil System
Gauges
Built Tranny
cndrm is offline
