Broken door handle - Ford Powerstroke Diesel Forum
Old 01-27-2007, 10:27 AM
Broken door handle
Lately I've been having a problem with my door, doesn't like to open very much, I opened it up and looked for an adjustment or anything, didn't find anything. Eventually it just broke. Does the cable in there stretch or anything? What makes it quit working?
Old 01-27-2007, 01:57 PM
LMC Truck has an exploded diagram of the inner workings of our doors in their catalog. Most likely they will have the part you need.
Old 01-27-2007, 02:36 PM
u need a new latch/cable assembly.....when you get the door panel off you need to see if where the handle attatches to the door...check and make sure it didnt split the sheet metal. Obviously you need a handle if its broken too....its pretty common on OBS trucks....
Old 01-28-2007, 06:47 AM
7.3 tech, supporter
Marc's right, the door handle on these is just held to the door with 1 tab and 1 screw with a foldover clip and it tends to tear the foldover clip out of the sheet metal. A cheap fix is to remove the door panel and use a hammer to flatten out the sheet metal where it broke and reattach the door handle using a 1/4" bolt with a fender washer on the back.
Old 02-08-2007, 08:00 PM
Send a message via AIM to therealdgh Send a message via MSN to therealdgh Send a message via Yahoo to therealdgh
Or, you can do what I did. I have a bunch of knock-outs from electrical boxes - they are a little thicker than standard washers. I drilled a hole in one and put the clip over it so I could use the same bolt and clip. I bent the torn sheet metal back into place and held the washer/clip with one hand while screwing the bolt into place. Works like a charm.
