CC rear window regulators - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-03-2014, 09:28 AM Thread Starter
I need some help. I have. 97 f350 crew cab. I need to replace the rear window regulators,but I can't find replacement parts for power windows anywhere.
XMoToX925 is offline
post #2 of 6 Old 07-28-2014, 07:14 AM
lpzd's Avatar
does the motor spin but gears not moving?
if so remove the motor take the plate off the gear housing you can use 3 nylon bushings from hardware store to fix the broken pieces
lpzd is offline
post #3 of 6 Old 07-28-2014, 06:52 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You can also get the nylon "dogs" from the HELP! section at the auto parts places. Some folks will even use 5/16" nuts for the dogs (I would prefer the dogs to disintegrate than the motor or regulator gears). Cheers!
Patrick Feeley is offline
post #4 of 6 Old 07-30-2014, 02:30 PM
lpzd's Avatar
didn't even think to look there.
oh well
lpzd is offline
post #5 of 6 Old 08-04-2014, 01:53 PM
Crewcabber97's Avatar
I just did a motor on the rear passenger door on my crew. I did it the easy way and drilled two holes to get to the two screws you cant see. Easy peasy.
Crewcabber97 is offline
post #6 of 6 Old 08-07-2014, 07:51 PM Thread Starter
I found a used regulator. The don't make new ones for power windows.
