Dash Lights and Temp. Control lights. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2014, 08:54 PM Thread Starter
Axlesteel's Avatar
Garage
Hello guys. Im in the process of changing the factory green dash lights and temp control lights to red. I have changed my dash lights no problem. I took the gauge face off and scratched off the green coating and then put red leds in the back where the factory bulbs go. I have now got to the temp control. I peeled the face off.... annnddd totally messed up the face when i tried to scratch the green off. I realize i had made a mistake. But a trip to the junkyard with fix it no problem. What should i do for the temp control? Any Ideas??
1997 F-250, SD Axle Swap Front and Rear, 4.10 LS, 20x10 -24mm, 35x12.50 Thuderers, E4OD W/ Shift Kit, Upgraded Torque Converter, Upgraded Trans Cooler, Ladder Bars By Me, TS-6, Baby Swamps, 3" DP to 4", 6637, PHP Tuning, Gauges, and A Lot of Lightbars!
Axlesteel is offline
post #2 of 4 Old 06-24-2014, 12:03 PM
Crewcabber97's Avatar
Get the new face or a couple and remove the green and put your red lights in.
I didn't remove the green and used blue led's in both the gauge and temp control.
Crewcabber97 is offline
post #3 of 4 Old 06-28-2014, 04:34 PM
WelchyBoy833's Avatar
What LEDS did you use for the dash and hvac controls?
'97 ZF5 4x4 340,000 K&N full intake 3''dp to a full 4'' straight pipe Superchips tuner
WelchyBoy833 is offline
post #4 of 4 Old 06-28-2014, 04:59 PM
They were jtech/brute lights from amazon I think they were 10 for 3 dollars and change. They are 194 replacements.
